Went and picked up the Stagea from Toll today, well I picked it up, drove it down the road the to the nearest petrol station (just) as it was cutting out everytime I pulled up to make a turn. What a great first experience in a new car!
The problem has been diagnosed as a possible Air Flow Sensor failure.
I'll tell you what happened and you can give me your opinions:
1. Car hasn't been driven for 3 months so that may have an impact here.
2. Will start and idle
3. You could initially creep it away on idle and get it moving, this seems to have become harder to do.
4. Once I did get it moving it cruised along ok seemingly, I didn't make any serious throttle inputs though as I really didn't want to stop in a busy industrial estate full of speeding Semis!
5. Diagnosed as AFS fault by starting car, unplugging sensor and being able to rev the car up (running rough then of course) before it would stall.
6. You can't rev it up at all with the sensor plugged in.
I spoke to the Compliance shop and they said they had no issues with it and drove it a short distance without drama. That would have been last week.
Next question is where can I get one quickly and how much?
I have the option of sending the existing one off to be tested and repaired, that is an $80 charge to test first.
Any help would be great!
I have a shot of the Stagea on the back of the truck... Not the arrival I was looking for...
Cheers
;) Luke :P
https://www.sau.com.au/forums/topic/115021-air-flow-sensor/
God damn Luke, bad luck... my cosmiserations to you.
Dont let it getcha down; they are a top car for sure - something you'll be able to sort out with an exchange of a couple $$
How was the problem diagnosed, ie via #5, did you get any error codes as such? Try a ECU reset? I dunno - maybe do this post in the forced induction section, as it'll definately get some experts thinking there & replying, for sure.
Edited by Tangles
https://www.sau.com.au/forums/topic/115021-air-flow-sensor/#findComment-2118398
My 96 was complied by Iamshe on the coast. It too cut out three times at low speed on tight turns. When I queeried Iamshe Phil said it was the shit petrol from the land of the rising sun. He was right. One fill of e10 plus and the Stag flew.
https://www.sau.com.au/forums/topic/115021-air-flow-sensor/#findComment-2118434
Hold the phone!
Crazy problem solved, the guys at the garage (where my Dad works) opened the air box and found a piece of the bonnet lining covering the hole on inside the intake side of the box!
Not sure how that got there...
Thanks for your input, car is driving well now so I am told!
Sad on the back of the truck:
All good now, picking up in the morning and giving it a very good clean!
Cheers
Luke
https://www.sau.com.au/forums/topic/115021-air-flow-sensor/#findComment-2118457
When I was on the cruise I organised on Saturday, I saw that (or a very similar) lining on the inside of the airbox, and was told that it's a sound-deadening device for the induction noise. It was only held on by a few brittle plastic clips, and Andy (EGA41T) removed his from his S2.
It IS meant to be there, but maybe the one on yours has just fallen apart over time.
Doesn't matter - the removal of it will not cause any problems, and may even benefit airflow slightly...
https://www.sau.com.au/forums/topic/115021-air-flow-sensor/#findComment-2118834
mmMMmmMMMm black, sweet! Also if you were to replace the AFM, buy a Z32 one as the replacement, they are a but more but have much better resolution!
Not quite the start you wanted but good to hear it was a relatively quick and cheap fix!
https://www.sau.com.au/forums/topic/115021-air-flow-sensor/#findComment-2119444
I pulled the sound deadener from the airbox of my S2 when i put my K&N in. It coveres about 1/2 of the filter & The induction noise volume increase was minimal.
No way it was deadener, paper thin material that was all coming away from the bonnet liner...
Goes well now though, clean up tonight then I will see what I have really got myself in to.
Cheers
Luke
https://www.sau.com.au/forums/topic/115021-air-flow-sensor/#findComment-2119573
at least the RACV truck would have been free no?
$250 (about 110km) so not real impressed...
Wasn't really an RACV deal, just lucky to know the right people at the right time, could have been much worse.
Luke
P.S. Thanks Tangles!
https://www.sau.com.au/forums/topic/115021-air-flow-sensor/#findComment-2120930
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
