As description states I need to get rid of this, it would be perfect for someone looking to go top mount turbo but who doesn't want to spend $$ on greddy or wait weeks for a custom job.
Looking for round $500 or offers?
Please PM with queries
Got any specs on the volume, runner length etc ?
Also some close up pics of the inlets and welds would be good too, just to see quality.
Cheers
EDIT: Postage to Gold Coast, QLD would be cool too :) 4213.
Edited by benigno
Sorry no specs on the volume, runner length would be virtually as standard. can get pics if you look but the plenum has been proven with big psi & hp as its off this car:
http://www.skylinesaustralia.com/forums/in...topic=80800&hl=
Leave your email and i will forward more high resolution pics and postage costs
The throttle bodys only 65mm
Not sure on power difference, as you still use the standard runners, you still use the standard fuel rail.
Never saw any GT35rs for $900, doubt you'll find them that cheap
    • Might piggy back off this thread since there's been a good discussion about PWM.   I purchased a Walbro 460 F90000267 and have been looking into PWM to understand it. It was purchased more of a future proof as my original OEM fuel pump died (r33 below 200kw) and figured I'd just upgrade it to this. That's when it hit me that a pump this big can cause more dramas with such high amperage draw and heating of the fuel pump being on 100% all the time in such a mild setup.   I have a Nexus R3 and slowly collecting power mods but I was looking into the PWM feature on the NSP software:   Then looking at the graph from the fuel pump:     Am I safe to assume reducing duty cycle to 50% for example would make the pump run like a 230/lph ? Where does the PWM come in all of this ?   I've gone down the rabbit hole of PWM fuel pumps and it seems there are many differing opinions on how to go about it 😅
    • Thank you, this will keep me busy for a bit.  I will update progression.
    • That specific one would be an exchange part, meaning I'd have to send mine to them. Plus it looks like a non AWD sump, which won't work for me. There is one or two shops in my country that I can ask to do a sump extension job and it'd most likely end up being cheaper than sending mine to AUS or NZ and getting one back, and quicker too.
    • Rear turbo is leaky, most likely at the oil drain. From what I could see with my boroscope it seemed to have seeped out at the very top of that return hose. Is it possible that the oil climbs up that hose to then leak out? Yup, coolant leak on the hot side of the engine, only noticed after seeing clear rusty residue in the block right from the turbo oil feed downwards to the pan, and red droplets hanging from the pan. No clear sign yet from where it comes, and most of the lines there are hardlines right? Last year, seeing those red drops, I thought it was power steering, will be glad if that is not leaky at least. Another leaking hose I found by chance is the lower of the two heater core hoses coming from the firewall to the back of the head. That one is not too bad to get to if I have to replace.
    • I think for response I'm already kind of out there no? he -5s are not the best pick for that as the Internet tells me. Maybe I should switch to -7s while I still can? Though that almost definitely warrants an engine pull along with the other issues I have.
