Nissan Genuine Part Numbers Register
Always Double check "Quoted" Part Numbers.
This thread is used for nissan genuine part numbers.
Post any nissan part numbers you have here so other members can find and use them.
from discopotato03:
Hi all , am going to start a Nissan part numbers register for Skyline R33 GTS25T's (ECR33) and will add any that I buy genuine . I dare say mine will come through John Robinson Nissan of Rockdale in Sydney on the Princes Hwy . Before start I have no financial interest in this organisation and pay retail like most plebs .
Also - You MUST check any part numbers I or anyone else quotes to you because I at least will take no responsibility if the number is incorrect and you order in expensive potentially non returnable parts . That said I will do my level best to get it right but I'm not infallible .
!!! Use this information at your own risk and double check the part numbers with your dealer !!!
  • 6 months later...
  • Replies 80
Posted Images
ive been keeping a list of part numbers that i come across on the forum. this is what i got and what i need. if anyone can fill in the blanks that would be great. SLIMVLT maybe you could?
Tensioner.................genuine??....................NSK 60TB0683 EA7L 806
Idler........................genuine??....................NSK 56TB2801B01 ENSL 309
N1 oil pump..............15010-24U00
Norm water pump......21010-21u25
N1 water pump..........21010-24U27
Fuel Filter..................Z200 normal Z32 bigger
Oil filter....................z145A
Timing belt...............13028 5L327
Crank seal................13510 10Y10
Cam seals................genuine ??...................G00084 non genuine
Drive Belts...............4pk0855 $17.99
...............................4pk0925 $27.99
...............................3pk0855 $23.99 not sure if theyre all genuin nissan or whats what ha
cheers guys. if anyone can add prices to these that would be great too.
Edited by (B1) MR_fanny
  • 1 month later...
from discopotato03:
Brake/Clutch - "Cover Pedal Pad" same as N15 Pulsar 46531-89910 .
"GSKT-AAC VALVE" 23785-57YOO .
Side Feed Injector Seals .
"INSUL F/I UPR" 16635-53JOO .
"INSUL F/INJ . LWR" 16636-72POO .
"O-RING HOU UPR" 16618-1OVO5 .
"O-RING HOU LWR" 16618-53JOO .
RB25 Exhaust Gaskets
Manifold Gasket 14036 21U00 $78.46
Turbo Dump Gasket 1445 V2700 $24.55
Turbo Flange Gasket 14415 4P200 $29.09
Oil Line Washer 15189 01P00 $2.22
Water Line Washer 15193 P9000 $1.11
These are direct from Nissan Parts and were for a 1997 R33 GTS25T
The parts were available 1 day after ordering them.
  • 5 weeks later...
  • 2 months later...
does anyone know the part number for front caster bushes, or where i can find them. mine are all cracked.
Have a look at nengun in the nismo section.
http://www.nengun.com/catalogue/search/5
They have all bushes.
Cheers
  • 5 weeks later...
  • 6 months later...
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
  • 3 weeks later...
Does anyone know the OEM part number for a new Engine Wiring Loom For A Series 1 R33???
Cheers.
Throttle Positioning Sensor: A22-646-J01 Air Flow Meter: 22680 02U00
Cam (Crank) Angle Sensor: 23731 08U00
ECU: 23710 21U00
as for '93 Series 1 R33
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
    • 😂 thanks guys. The diagram i had did not have the breather on it at all. Much appreciated.
    • Geez, engineers fees have definitely gone up. Mine back 2007 cost me all of $300. Mind you, I had to go back to him a few times to get him to write the correct things on the report after he'd inspected it. Things like wrong exhaust size, wrong wheel sizes, etc etc.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
