  • Replies 80
Posted Images
Thrust Bearing - RB25 (99% sure RB20 Aswell, Will check tommorow) MALEX P/N GSB335
Also does anyone have the Bosch P/N for a VG30DETT AFM only got a listing for the NA version at work (are they the same?)
RB25DET
Valve Stem Seals - 13207-D4201
Cam Seals - 13042-16V00
Head Gasket - 11044-75T02
Rocker Cover Gasket IN - 13270-58S11
Rocker Cover Gasket EX - 13280-58S01
Shifter Bushing - 32861-01G00
VRS Kit cost me $217.62inc GST
Been quoted $99 for Headgasket
Edited by lunjiaow
  • 4 weeks later...
  • 2 months later...
  lunjiaow said:
RB25DET
Correction here. The exhaust rocker cover gasket is 13270 also, not 13280
  • 3 weeks later...
Manifold Gasket 14036 21U00 $78.46
is this part number for the gasket between the engine and the manifold? or the manifold and the turbo?
if it is between the engine and the manifold, what is the part number for the gasket between the manifold and the turbo?
thanks in advance
  • 3 months later...
  • 1 month later...
  Jamesrb25 said:
Ancillary drive belts genuine Nissan
3PK845
4PK850
4PK910
R33 seriesII
wish i saw this 1 before i saw the first post, i got the 855 of the first post, and the belt is a bit to loose and squeals damn it lol, i will end up buying another new belt soon as this will just drive me crazy,
Cheers
  • 1 month later...
Parts for 100,000km service for R33 rb25det
Lander Motor group - Blacktown - 14 March
NI-21010-21U26 - pump assy-water - $147.59
NI-13028-5L327 - belt-timing - $83.09
NI-13070-5L300 - tensioner assy-belt - $93.38
NI-13074-58S00 - puley assy-idler - $275.82
NI-13042-16V00AU - seal-oil, camshaft - $16.81
NI-13510-10Y10 - seal-oil, crankshaft - $22.96
NI-15208-H8911AU - filter assy-oil - $9.49
These are retail prices, i managed to get the water pump and belt cheaper
They had all these parts in stock!
I ended up buying ilder and tensioner at Autobarn for
$165 and $47
  • 3 weeks later...
  • 4 weeks later...
  • 1 month later...
  • 3 weeks later...
these are the part numbers i got and prices
tie end rod (part that attaches to hub) right- pn#4852115u26
lh rack bush- pn#5444503u00
rh rack bush- Pn# 5444419u00
4 bolt manifold to turbo gasket 14445v2700
not to sure if it is right but i told him what i wanted and that it is for an ser 1 r33 gtst
hope it helps
  • 1 month later...
