  • 3 weeks later...
  • Replies 80
Posted Images
Anyone got the part number for the dust boot which goes on the shifter to keep crap out of the shifter pivot?
Cheers
Aaron
Not sure of the P/N but just jap have them for $25
http://justjap.com/store/product.php?produ...=263&page=2
  • 4 weeks later...
  • 1 month later...
FULL RB25 NEO GASKET KIT 10101-AA525
R34 RB25 BOTTOM RADIATOR HOSE 21503-AA000
R34 RB25 TOP RADIATOR HOSE 21501-AA000
R34 RB25 FRONT HEATER HOSE TO BLOCK CONNECTOR 14075-04U00
R34 RB25 REAR HEATER HOSE TO BLOCK CONNECTOR 14075-AA505
R34 RB25 THERMOSTAT COVER 13049-AA000
  • 4 weeks later...
  • 2 months later...
R32 GTR Front Windscreen Centre Moulding / Retainer 72752-04U00 Approx $85 from Nissan (72811)
R32 GTR Front Windscreen Moulding / Retainer Set 72750-04U10 Approx $250 from Nissan - Replaced by 72750-04U60 (72810)
  • 1 month later...
  • 4 weeks later...
Part numbers for ECR33 Series 1
Radiator clutch fan (plastic blades)------------------------------9212110Y00
Front windscreen mould fastener (attached to body)----------7272522U00
Front windscreen mould (clips into fastener)-------------------7275222U00
Rear windscreen mould fastener (attached to body)----------7978022U00
Rear windscreen mould (clips into fastener)-------------------7975222U00
Standard thermostat---------------------------------------------2120042L06
CORRECTION TO THE ABOVE POST!
The radiator fan arrived today, looking an awful lot like an A/C condenser fan. They ordered me the wrong part, so.....
Radiator clutch fan (plastic blades)-----------------------------2106075T01
A/C condenser fan (blades only not shroud)------------------9212110Y00
  • 3 weeks later...
  • 2 months later...
Anyone know the part numbers for ECR33 series two headlights L&R?
Late reply, but for the Googlers...
Series 2 R33s have H1 bulbs for their head lights.
Not sure on high-beam bulbs.
Not sure on parkers.
Not sure on fog lights.
Could someone please let me know what parts the above three are? (I need them for my car :P)
  • 4 months later...
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
