so i have an r32gtst with an automatic transmission (and yes, i like it like that)
about 2 years ago, my brain saw a light bulb and decided to make me fit a large trans cooler which i purchased cheaply from supercheap. it has never given me a problem and works well, and you can feel the warmth coming throug the cooler when you touch it after driving
BUT... instead of mounting the trans cooler in front of the radiator like it said, i decided to mount if in the front bumper on the drivers side, so its like a mirrored location of the stock intercooler. i cut a hole in the guard behind the trans cooler, and made some ducting so that air flows through the cooler, rather than around it.
recently, whilst pondering the damaging effects of a car sitting in traffic in the brisbane summer heat, i decided to make a switch that is in the dash that is connected to my electric aircon fan. when in traffic (or after a hard drive) i turn it on to get some extra airflow through the radiator. it makes a huge difference and i can feel the hot air from the drivers window if i place my hand out.
so it got me thinking (yeah, it hurts)... what if i mount a mini thermo fan onto the auto trans cooler, and wire it up in parallel with the aircon fan, so that when i flick the switch, the transmission is also cooled in those stressful traffic situations?
I did some ebaying (is that a word?) and found some 7" thermo fans that were pretty cheap.. is this going to make any difference at all, or am i barking up the wrong tree here?
any automatic guru's out there that want to shed some light?
thanking you kindly,
Warren
You could give it a go...
Although i'd go for having a direct switch you can control from the cabin...Maybe go for the switches that light up when on so you dont forget to turn it off.....
There are off-the-shelf tran coolers that come with fans already attached but, normally you would have one if the cooler is placed somewhere with limited air-flow.
Yes, the fan will cool the fluids down while in traffic, but if you place it infront of the cooler it may restrict the cooling capabilities of the cooler while the fan is off during cruising speeds. Is the fan reversible (ie. can it suck air)? If the fan is reversible & space permitting I'd place it behind the trans cooler.
But, as Craved suggested if the current position is receiving sufficent air flow I wouldn't think one is necessary.
Great to see someone else is not afraid to voice a positive opinion on an Auto Skyline.
I also prefer the Auto although tricked up and with a 2700RPM high stall converter.
For this reason I have a massive aircond condensor as a cooler with two 12v dc Computer fans on it in place of the original I/C -as heat is the killer of auto's -especially when stalling up on the line :ban:
You cant do enough to keep the trans fluid temps down and prolong the life of the trans as far as I am concerned even if you dont stall it up often.
I'm not opposed to the idea, but just wondering if its needed.
If the car is idling at the lights on a hot day, the trans isnt really generating a lot of heat (this occurs when you torque it up)
If you already have a trans cooler it would have better cooling than a standard car, (and stock autos dont have many problems) and I would be a little worried that the fan might restrict air flow and in effect make it worse when you are driving, and when the trans IS making heat.
I am a big fan of trans coolers (I have one on my auto) but im not sure if the fan will offer a lot of benifits
perhaps not mounting it directly on the cooler itself then and just blowing air onto the cooler. wont cause any restriction of the air flow when moving, and will keep air moving passed it when stationary..
best of both worlds i guess.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
