the down side is it doesn't do much at all. Under high load and boost it does virtually nothing. It helps to cool the ic down quicker after a period of boost (ie: works ok when 'off' boost to remove heat soak faster).
Water or alcohol injection on the other hand is worthwhile.
Hi Guys, the real world effect of water spray on intercoolers is something I must get back to data logging one day. I have only had one day's exposure to this when I filled in for a rally data log interpreter at the Canberra Rally a few years back. The team had an Evo with an intercooler water sprayer (actually metho and water sprayer would be more accurate).
I was mainly doing suspension data analysis, but I did sneak a peek at the engine log a couple of times. The effect of the spray on the inlet temperatures was quite noticeable, which was a bit of a surprise to me. Up to then I always though of them as a bit of band aid really. Why not just put the right sized intercooler on in the first place? I guess the issue was to do with the homologated sizes and airflow to the radiator, which stopped them having a whopping great intercooler. Plus it may also have to do with response, as a whopping great intercooler is going to slow that down and rally cars need good response.
Unfortunately no numbers, so I will have to have a go at doing it on the circuit race car, maybe next summer.
Bottom line, I guess the manufacturers would not have bothered homologating it if it didn't work.
Hope that adds to the discussion.
Sydneykid,
I have tried (still have) a pieltier and heat sink attached to my intercooler and also used 'freeze spray'. Some time ago I made a design for the freeze spray to be mounted and activated by a switch in the cabin (which autospeed kindly published in an artcile on freeze spraying intercoolers). The Autospeed article did some testing on a dyno (not ideal due to un-realistic airflow) and it revealed a very small increase with freeze spray and almost none with a water spray.
What I have found is that both the systems offer little extra full boost power, but are very good at bringing temps down quicker when the throttle is lifted or the car is at rest.
The air movement at speed is different to a dyno environment and as this is super critical to intercooler function the dyno has to be taken with a grain of salt.
Ooh rev210, that's tricky, so you have the cold side of the peltier (I spell it with only one "i", is that right?) attached to the cooler and the hot side to the heatsink? Very clever.
On the water spray I would have the "on" connected to the brake pedal, that way it will spray on the grid before the start and during the race in each braking area. That way, when I get on the power out of the corner, the cooler will be as cool as possible. A can of freeze spray would run out too quick, ok for a drag car though.
You're right about air flow on dynos, we have three fans and that barely simulates 60 kph. Need a wind tunnel.
Hope that stimulates some other thoughts.
Unless you know EXACTLY what you are doing or someone else does NEVER EVER inject anything into the intake. This is for serious tuners only and is a true receipy for disaster if not done corectly.
On a road car the expense of setting up a good spray system is similar to haveing a dump made for the turbo and that will provide much higher gains, on the road you will be likely to forget about it after a week or so anyway. I have had one in two cars of mine and never noticed any difference. Only time I did was in my mates turbo starlet with top mount, that helped heaps until water got down around the plugs ;)
Isopropyl Alcohol is just that... Another type of alcohol. Not refuting any claims here mind you... just pointing out to anyone reading that isn't familiar with the name that 'Isopropyl' isn't a substance by itself...
The chemistry lab lady at high school used to wonder why we kept asking for half litres of it every couple of weeks... :D
we just said we had to clean a LOT of really BIG fax machines :(
Adrian
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
