  • Replies 63
Just been looking at my broken box at the mechanics less than an hour ago.
Okay, my reverse selector fork broke, leaving the gear to float back and forth, chipping teeth and sending them floating about and gunking up the works.
The hardening on all the other gears was chipping away.
The input bearing and another one were also shot.
I smashed my Rb20box....still drives.
Typically the problem areas are as follows.
Gearset too weak
Synchros too weak
Bearings too weak
Input shaft too weak
Pretty much the best way to strengthen an RB20 box is to throw it away and buy an RB25 one. Unless you have about 6-7 grand to play with. The standard 20 box can handle 200rwkw day in and day out as long as you don't smash second too hard. Mine went 2 years on 200rwkw and about 6 months on 240 then it was getting hard to select 2, 3, 4 and 5.
I have the RB20 box which you can have for $50..... plus freight unless you wanna pick it up from Brissy.
Gearset too weak
Synchros too weak
Bearings too weak
What fluid and clutch...i was makign about 190-210rwkws for about 12 months (150,oookms to 165,000kms), then between 215-235, ocassionally 250 odd rwkws for about 8 months with plenty of track work thrown in and my box isnty even makign any funny noises....and i run semi slicks
Im forming the opinion that its a combination of luck, the way i drive and the fact that i only have a baby single plate clutch and am using very good fluid, (not redline...but Castrol) ?!?!?!!
That said i no i wont cheat death forever...but trust me, if the box is 20kgs heavier, thats half a tank of gas, and at the track you can feel when you go out in the morning on a full tank, then syphon 30L from the tank and go back out...the lap times dont lie
Well i can lose 10kgs, and im losign that cause im now a fat fark, forget the car. But i want to keep the air con and all that because it still is a street car, and if it happens to go quick one day, i dont want ppl copping out and saying its stripped...it would be so much easier/cheaper if i didnt care what ppl thought of the car :D
I guess if your not snapping them it doesnt matter. And to be honest most of it is probably your clutch not snapping them.
But if you do start snapping them, you have to start to think. The extra 20kgs might be worth it. If you have to constantly replace or rebuild rb20 boxes, it kinda takes the fun away. That is assuming you are still doing track days for mostly fun, and not some form of paid competition.
That's if the actual gears are heavier... Then you'd also have to work out any differences in design to work out differences in energy lost in the gearing action. Then you'd need to know how much extra was in the actual casing compared to the gears.
Don't think it would be that simple.
My gearbox was tempremental shifting into 2nd. When dead cold it would have a slight choke when engauged the first couple of times then would be fine.
I've now canged the oil with a nulon additive and it engauges from cold alittle smoother but after a couple of spirited shifts that didn't quite engauge 2nd and munched it, it now has become a tempremental gear all the time so now I have to baby second which is begining to grate on me.
I highly suspect 99% of the damage had been caused well before I got my hands on the car and second gear as it cops a fair whack of torque and usage has lost the effectiveness of its synchros so is now crunching on engaugement. Unfortunately there's only one way it can go from here!
Which puts me in the same boat as you guys = 2nd hand gear box (unknown condition)
Reconditon (pricey at best)
Rb25 box (same as GTR, strong but once again
risky and pricey)
hi guys i'm a victim of blowing the rb20box - with 230rwkw clutched it in 3rd and 3rd exploded :S
i've done a 25box conversion and having major issues with clutch slipping, if anyone has any advice please read my thread and some feedback
http://www.skylinesaustralia.com/forums/in...howtopic=117570
thanks
-Matt
I have exploded three of them! This neo r32 one is dying verry fast i think... My old rb25 powered r32 blew two.. I reved it to limiter and grabbed second then it exploded... I pulled it down with dad i slit second gear in half... Not bad boxes,but they dont like rb25 power and torque..
i have an RB30 in my 32 now still with the 20 box and naturally i'm looking to upgrade, I have spoken too PPG and they can rebuild my gerabox with the works but the price is a hefty $6100, I think the 25 box is the way to go!
One of my friends has smashed 3 rb20 boxes with about 250 rwkw.
The weak links in the box appear to be as mentioned above, basically everything in it. The ways it was smashed was:
1. shifting hard into 2nd.
2. near the top of 3rd gear, foot planted. Once the torque/power came in, the gearbox literally just exploded.
cool. just had to put one in a 32 non turbo!
was klnocking at all revs regardless of wich gear.
it turnes out that gay little bearing on the sandwich plate failed.
countershaft.
(bearing race ball cage came apart.) suprise suprise.
so it seems it really is luck of the draw really. concidering a na. rb20 completly stock lunched it lol :wave:
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
