Hey Guys,
I wanted to know is it possible to get a 2 piece caliper/2 piston with a sliding plate system setup for a R33 GTST. I currently have the standard calipers for a R33 GTST which most of you are aware is a 1 piece caliper with 4 pistons.
Any feed back would great.
Cheers
Babylon.
you would have to use the smaller disc but
orrr use v35 skyline gt brakes (the povo version/non brembo) im pretty sure they are a 298mm disc so the calipers should bolt up
i dont want to change my disc's if i dont need to the issue is i want to change my standard calipers to a 2 piston setup and not lose any braking power just wanted to know if that was possible.
WHY? what is wrong with the 4 piston ones you have? moving to a sliding caliper is a bad move.
Beer Baron that’s exactly what i think
The reason i ask guys is that my Break Squeaking issue has come up again.. and ive taken the car to 2 brake\clutch specialist
http://www.skylinesaustralia.com/forums/in...topic=73439&hl=
1st has advised that i need to replace my discs but cant guarantee the noise will go away and to be honest I don’t want to spend $800 on a issue that “may solve the problem”.
2nd has advised Slotted Discs will not solve the issue. Noise might get even worse.
My uncle the mechanic who is helping me with this has different opinions he believes its the callipers that are causing this issue he wants to see if I can get different system to the standard one Basically im trying to prove him wrong.
What state are you in. The Nissan 4 pot caliper is superior to any twin piston sliding caliper, dotn even think about it, it will be expensive and a drop in brake performance.
Next move is go to another brake place. If the rotors are true and above thickness then leave them be. Any brake guy worth his mustard will get rid of the squeel for far less then what you have quoted for replacement rotors...it shoudlnt be difficult...just need an experience brake guy to spend the 60 mins to fix your problem
Let's see, there are around 4,000 Skylines in Australia and over 2 million in Japan with this style of calliper. Miraculously you are the ONE with brake squeel that can't be fixed.
I don't think so Tim.
:) cheers :O
Correct me if I'm wrong on this, people, but this is my understanding:
The whole reason for using more pistons in a caliper is to get more braking force through greater surface coverage when you apply the anchors, more friction, and (as a by-product) more heat transfer.
Reducing the number of pistons acting on your brake pads means less even wear of the pads, and most probably the discs, as well as more potential for disc warping (depending on the size of the pads in relation to the pistons).
Thanks guys that’s exactly what i assumed i told my uncle that im down grading my brakes by doing that
i just needed a confirmation.... im in Sydney West.. im just going to take the car to another Brake place someone that is actually willing to put time into the problem (any recommendations?)
Thanks again
Babylon.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
