Item: R33 Nissan Skyline
Reason for Selling: want a 4 door 4 wheel drive. possibly swop for bug eye wrx
Price and Payment Conditions: $22500
Extra Info: Late 1993 Nissan Skyline R33 GTST (series 1)
This is a reliable high spec car going for a very reasonable price. No expense spared in the modification process and always used top tuner and mechanic (Chapman & Chapman Automotive)
Excellent performance but still a daily driver
Power: 350HP ATW
Miliage: 85 000 kms
Engine Modifications:
GCG Hi flow Turbo
Tomei 550cc Injectors
Blitz Front Mount Intercooler (plumbs back to standard holes on passenger side)
Os Giken Exhaust Cam Pulley
Turbosmart type 2 BOV
3” turbo to CAT
3.5” CAT back exhaust
3” Hi flow CAT
HKS mushroom filter (with spare insert)
Z32 AFM
Bosche 979 fuel pump
Bosche fuel damper
Sard Fuel pressure regulator
Carbon Fibre cold air intake box, with standard snorkel fitment
19 row oil cooler
Oil filter relocation kit
Electronics:
Apexi Power FC, with hand controller
Apexi AVCR boost controller
Auto meter Shift light + Tacho
Suspension and Brakes:
Tanabe coilovers
Front adjustable castor rods
Rear Whiteline camber kit
Whiteline differential cradle bushes (pineapples)
DBA 4000 Rotors with Ferrodo race spec pads
Front and rear strut braces
Exterior:
Carbon Fibre GT wing (conforms to QLD road rules and is legal)
Flush boot “drift” wing
M spec front bar, with intercooler space cut out
400r Side skirts
Black Bonnet
Other:
Radiator air guide
Skyline floor mats
Immaculate interior
17” wheels 9” wide rears
255 Nankang’s on rear
235 Toyo’s on front
Mines 300kmph Speedo
This skyline has well over $12,000.00 worth of modification done to it and all has been carried out by Chapman and Chapman automotive.
Serviced every 5000kms and always used Motul 8100 oil.
Timing belt was changed when I got the cam pulley installed (3000kms ago)
Gearbox oil was changed to redline shockproof as soon as I purchased the car (march 2004)
Contact Details: neil smith 0431912336 [email protected]
i am in no rush to sell this, its worth heaps more then the asking price
will swop for bug eye WRX
https://www.sau.com.au/forums/topic/115120-350hp-r33-nissan-skyline/
I will gladly vouch for this car. The sound of the turbo at peak boost is simply amazing.
Very reliable as well because its being looked after & tuned by Chapman & Chapman.
:ban:
sedan headlights you mean?
no acco history, the previous owner changed them as the stock lights plastic/glass was all blurry and damaged.
i got the car cheacked out when i bought it from him and there were no signs of any accident
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
