hey ppl i got a 93 gtst manual which consits of
-Front mount
-pod filter
-full 3 inch exhaust with split dump/front from batmbl
-greddy boost controller set to 11 psi
the results were 181.1HP
max hp came in at about 5100 rpm however my boost seemed to drop back to stock psi as the revs got higher any idea ? the guys at hyperdrive said the ebc might not hav been set up properly il try ge ta pic of the dyno sheet asap
cheers sam
Edited by Sammie
https://www.sau.com.au/forums/topic/115128-had-my-car-dynoed-today/
  • Replies 104
Posted Images
i think they came with the RB20DE and RB20E, not the RB20DET though. I would say its a RB25DET. 181rwhp @ Hyperdrive seems a little low, im gonna go there in a few weeks to get mine tuned. I have same mods with SAFC II and no boost controller. will compare it to that once done.
yea its a rb25 guys the bloke there said i should be looking at getting a power fc just was dissapointed hearing ppl with the same amount of mods reaching 200 + was kinda hoping for atelast 200
sorry but thats a bit ambitious...
the boost is probably too high for the stock computer for a start...that wont help...other than that you've got an exhaust and a pod....
justin911 for example is just making 200rwkw and has full 3 inch zorst, fmic, 12psi and power fc...
you may have read rong it perolly sed 181.1kws???
I seem to agree with Supadan.
While power figures do vary from car to car and dyno to dyno, it does seem like a fairly low power output for the mods you have listed.
Assuming that everything is running properly, and AFR's are good i'd be expecting higher myself. 180kw's sounds realistic. 180 hp seems low.
But like I said, the low power could be due to any number of things.
Dyno readings aren't gospel.
Edited by insu
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
