looks very flat...
i got my stock 33 dynoed (albeit in 3rd gear due to incompetent dyno operator) so yeah, its supposed to be in 4th, but in 3rd i got 182rwkw and a very steap graph compared to that 1.
going in for another run in 4th (the way its supposed to be done) next week sometime (only has a cat back atm) so i'll see how it compares to what you've got
  • Replies 104
Posted Images
Stock R33 @ 182rw/kw?? Doesn't sound stock to me...
My SII R33 pulled 144rw/kw (193HP) stock standard... (7psi)
3"split dump, Hiflow CAT and 3"CAT Back gave me 165rw/kw (220HP)... (8psi due to split dump)
Everything else is stock...
181HP = 135kw which is only 9kw less then mine... therefore its possible if your engine/turbo isn't in good nick..
What fuel were you running? How hot was the workshop temp? These all can easily make a big difference
Personally I would try a fresh tank of optimax/ultimate and dyno it in the morning or late afternoon...
Regards,
Sarkis
Regards,
Sarkis
read carefully, i said it was in 3rd gear...its supposed to be in 4th (which is what yours was done in)
another s2 R33 which has ~200rwkw was done in 3rd just to compare, and pulled 243rwkw, so it works out that mine would be roughly 140-145 if it was in 4th...
like i said, it was the dyno operators fault, so i'll be going somewhere else next week and getting it done again...only difference is now i have a cat back.
was running halfa tank of ultimate and my car was dynoed early in the morning to it was quite cold roughly 18-19 degrees im just confused why my boost dropped of sucha considerable amount practically back to standard psi
because you have a stock ECU, and it doesnt like going over 10psi..
even still, the power you got (being 9kw less than what QRI05E said he got stock) isnt really that low considering yours is the first of the series 1's being a 1993 model...where as QRI05E's is a series 2....its bound to be fresher, unless yours has had a rebuild, or his has been thrashed A LOT!
exatcly it aint dead stock why i aint to happy and i bought the car from autoworx which he freshly imported from japan with 90k on the clock i was talking to someone before and they think sumthings up with the boost because its dropping after certain amount of rpm
some 33's came with RB20DET's didnt they? and his is a 1993 model so maybe his is one of em?
No R33 came with an RB20DET from the factory you might be thinking of the RB20e that came out in the povo pack versions...
Chris
Edited by alphanumeric
it feels great to drive i admit im just searching for power and the gusy at hyperdrive said i should get the boost checked cause if my ebc is set to 11 psi shouldnt it stay ? or is it normal that it drops back down to 7 or 8sh psi at high revs
Whats your base timing?
Maybe thats been wound back as a safe guard for running shit fuel.
You'd loose a heap of power if it wsa running less base timing than it should.
Whats your intercooler like?
Maybe check for leaks in cooler pipework, leaking BOV etc.
It all helps!
The gear does not matter dick, if you knew anything about dyno's you would know that. Its merely better to tune them in this gear as the ratios are closest to 1:1. Fact of the matter is a power run in 3rd will only move the graph left, ie at a lower speed...
Also its amazing how many "happy" dyno's are around and how many "supurb" results happen.
Sammie
I would look into why your getting a low result, maybe a restriction, drop the exhaust after a run on the same dyno and compare, there may also be other factors that you can try.
Sammie
how can you say that?
how can a stock 33 GTS-T make 182rwkw when they are 187 at the fly. its not possible. and the car was bone stock.
again, how can my mates 200rwkw (in 4th) R33 make 243rwkw in 3rd?
well my car was on the same dyno as dezz's... and the result i got is consistant with results on other dynos... so unless the operator was doing something dodgy with dezz.... the dyno seems pretty accurate to me...... but yeah his car is 100% stock....
hmm guys this is real hard to explain but went to see aguy i knew had a look at the dyno sheet and looked under the bonnet for leaks etc he looked at the stock bov and saw that it wasnt blocked cause i hav after market bov connected near the pod he put some tubing on the end of it and connected it to another tubing line which is connected to the throttle body sorry im not good with motors but as i was saying i drove it and this time it actually felt like it was boosted however hit 1 bar so i let off straight away he turned my ebc off and i drove it was hitting .8 bar and felt much much better i could tell because the bov was much louder and could hear the pressure releasing alot more however in 3rd gear it almost hits 1 bar which i was told is veryvery unsafe for my car so i just putted my way home any ideas ?
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
