As rob has said, if you want PROPER comparatives, the dyno's need to be in shootout and strapped down accordingly. They also need to be the same brand (though I stand behind Dyno Dynamics) as you will get varied results on different brands and obviously TYPES of dynos. You can also have variances between same brands and different age dyno's its inevitable that
A DYNO IS A TUNING TOOL ONLY...but hey I know nothing
Sammie and others look at your dyno sheets as a BASIS to work from...or go somewhere else and then use that.
Paul spraying up that there will be a difference between 3rd and fouth gear makes me question some of the other info you so readily provide...please take this with a grain of salt, I am not here to have a keyboard war...
  • Replies 104
Posted Images
how can you say that?
how can a stock 33 GTS-T make 182rwkw when they are 187 at the fly. its not possible. and the car was bone stock.
again, how can my mates 200rwkw (in 4th) R33 make 243rwkw in 3rd?
Quite easily as I have seen and have proof, read my other post, this really is turning into a war of the keyboard...
ill re-iterate
it makes a difference if he/she is comparing to someone else who has a run done in another gear as the outputs look different. the power run is still a power run and its useful if tuning or comparing against a previous run in the same gear, but the common problem we see is 3rd gear runs typically do not compare against 4th gear runs.
ive never seen a 3rd gear run compare equally to a 4th gear run.
hey ppl i got a 93 gtst manual which consits of
-Front mount
-pod filter
-full 3 inch exhaust with split dump/front from batmbl
-greddy boost controller set to 11 psi
the results were 181.1HP
max hp came in at about 5100 rpm however my boost seemed to drop back to stock psi as the revs got higher any idea ? the guys at hyperdrive said the ebc might not hav been set up properly il try ge ta pic of the dyno sheet asap
cheers sam
isn't that abit low?
i smash 212rwhp @ 12psi on my RB25det with an Rb20 TURBO!, fmic, ebc, cat-back, air filter + cai. and this was on hyperdrive dyno
i took my car to j shop who fitted the ebc n found out my stock bov wasnt blocked off we he blocked it off n drove set the ebc to low boost which was .4 however still overboosted to .9 bar he fiddled around with tubing and bypassing sumthing until we got it right so now my high boost is set to .7 bar which worked it hits that and doesnt go further however after this i hav experienced more problems it wont hold .7 bar any further then 4500 rpm at 4500 rpm at .7 bar boost it will just release with my foot on the pedal, so now i hav another problem :sick:
' date='28 Apr 2006, 02:03 PM' post='2123558']
why the hell are you running a rb20 turbo????
so you're trying to tell me that my bog stock R33 GTS-T has 182rwkw.
and then there are people with front mounts running higher boost than me, better exhausts, and they have the same or slightly higher rwkw?
found out my standard bov wasnt blocked off and it was leaking went back to the sho i had it dynoed at and said that would of been the cause so a mate blocked it off and feels alot better however now i set hi boost to 0.7 bar when im driving it will reach .7 bar then releases and goes down to .5 bar and stays consistant till i change gear not sure the prob now
OK Sammie. Few pages back you where explaining how ur mate connected a pipe from the top of your BOV to the inlet manifold. Im no expert but i beleive this is needed to activate and de-activate the BOV. Because as you change gear the engine goes into Vacume and forces the BOV to open up. Now if this wasnt connected at all! your BOV was probably leeking on boost and causeing that power curve. After you mate connected it the leek was fixed and you found alot more boost.
I would just like to input into the 3rd and 4th gear dyno runs. I would beleive the only differance is the torque!
What happesnt when you put smaller wheels on your car??? faster acceleration right. Now doesn that mean smaller wheels increassed you engine power?? NO.. it just decreased you gear ratio.. therefore more torque @ wheels and faster acceleration. So its the same thing if you change down a gear it doesnt increase you power.. it just makes more torque at the rear wheels.
Its the same when looseing off a tight bolt... if it doesn't come loose you increase the length off the bar right, and the bolt moves. This doesnt make you stronger it just means there is more torque applied on the bolt.
Anyway thats my opinion!
im not saying you guys are wrong with the whole gears not making a difference thing
all im saying is, i have a stock 33 gts-t which made 182rwkw in 3rd.
that is not correct. i dont care what anyone says, you're a fool if you beleive a stock 33 gts-t can make 182rwkw...because if it makes that in 3rd, it should make the same in 4th according to those that say the gears dont matter...
i know of another 2 cars, on 2 different dynos that have both made more in 3rd than they do in 4th...and not by a little amount
Incompetent dyno operators!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
-Front mount
-pod filter
cheers sam
Wow, my RB20DET with just a 3 inch cat-back, pod filter and stock boost level made 177rwhp on the same dyno... Something definitely not right with your car!!!
Yes, that is what I am saying...............
And thank you NIB for helping out, geezuz I am close to insanity...
Edited by Bobjones
maybe your stock car has actually had a fully rebuilt blue printed & balanced engine with port/polished/flowed heads, intake & exhaust manifolds, with aftermarket cams and cam gears.....
all done in Jap land, all looking like a stock motor on the exterior....lol
just a thought....
2 add my 2cents, my 33 made 172kw with front mount, pod, cat back an 1 bar (14.7 psi) back in the day when thats all i had :)
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
