Hey,
Not sure how much this will help but I've got a 95 series 1 R33 GTS-T with:
K&N panel air filter
3 inch turbo back exhaust
Bleed valve (with the boost set to ~11 psi)
I got the car stock from Japan and had the guys at Hyperdrive in Perth, recommend and fit the parts listed above. The dyno, which was done before the air filter was replaced, came out at 228.3 HP. It really needs a Power FC to be fitted to sort out the power curve but it might give you something to compare with.
Maybe go back to Hyperdrive and have a talk with the guys down there, btw my boost dropped off as the revs got higher too.
Edited by Mike R33 GTS
  • Replies 104
Posted Images
cheers mate i went back to them and booked my car in for next week my car now cant even hold boost which is a real pain will hit .7 bar thendrop off eratically back to .5 and sit there so yea gonna get them to check it out n re dyno hope all goes well
Yeah, I have dropped the boost off a bit. I've got timing issues now, I need to get the spark plugs re-gapped but if that doesn't fix it I will need to get a set of spitfire coils put in. I'm going to put in a Hybrid GT intercooler in the next few weeks, gonna give the install a go myself and then get a PFC after that.
Cheers,
Mike.
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
