well how much is different? -
different body kit
different rims
engine mods?
exhaust mods?
interior changes don't matter.
if you really wanted one, it wouldn't be any different than bringing in a modded R34, just gotta find standard parts. Actually come to think of it, i don't think the kit may matter too much... as long as it's not too low, spoiler too high, etc...... hmmm...
TK R34 has non standard suspension parts (not just the strut), engine parts (boltons, but still), seats (big ADR no no), underbody diffusers etc.
I think the first reply says it all. Too much hassle. I don't forsee any compliancer who knows what a TK R34 GTt is to agree readily.
  • 3 weeks later...
Are they the only modifications to TK R34 GTTs?
My mate just bought one today (picks up tomorrow) and I've been trying to find info about the TK versions with no luck.
Pics of it are here http://ucn.dealernet.com.au/photo.php?ucni...515F063F3A58B2F
Edited by MattyP
a few of em came in under the old CPA import scheme... I remember back in 2002 or something HPI had a writeup on a black TK R34 GTt.
I almost bought a R34 GTT TK edition! but it was $42K!!! So i just got a 33 GTSt back in the early 'noughties'
Except from the bodykit and built in SatNav kit, i wasnt aware of any other mechanical differences... But, my point is that the importer was able to comply them!
  • 1 month later...
of course you can dude! here is what you do:
Give me your money - i'll buy it and drive it here in japan for the year it takes to be able to import it under the personal import scheme and then i'll stick it on a boat and it's all yours! no compliance costs and you get my personal guarantee that i won't drift it or take it to track days or gymkahnas! :(:P
As long as the engine modifications aren't severe then yes it can be done. We have imported several modified R33's and R34's because we have access to stock parts which can be swapped for the pits and compliancing and then swapped back afterwards. Car's with bodykits (not over the top of course), interior mods etc. will pass compliancing and the pits. We sent a R33 with a FMIC fitted over the pits a while back and passed no worries. If you would like me to go into more detail or have any questions just ask.
Cheers,
hey,
I saw a black one with a tommi kit and other associated tommi stuff all over it for sale at phantom motorsports in brisbane not long ago, i recall seing an odd build plate in the engine bay, but I only looked briefly so I can't be sure, might've been something else
mark.
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
