Hey Whyte,
Got just what you're after. check this thread - $8990ono inc rego.
http://www.skylinesaustralia.com/forums/in...8entry2084358
17" rims, mild kit ( nothing too wild), sports exhaust, etc etc - can even fit a kit and do a custom color spray ( Subaru WRC blue, Jag Green, Ford Acid Rush, Holden Tiger Mica, etc to name a few) for probably another $4000.
cheers,
Nathan
Hi Whyte,
I thought your thread read 'WTB' - now you want to swap instead? I'm really only interested in selling ( which is why I replied to your ad) but if you are prepared to send me an NRMA report on your car or send it to New Norfolk for an inspection then I may be interested.
cheers,
Nathan
[Hi Whyte,
cheers,
Nathan
thats okay nathan someone annonomously pm'd me about your car and said they checked it out in person and it wasnt in good condition at all. i have to pass.
thanks
I've seen it and it's actually not a bad car. if you didn't like it, why did you offer to swap one of yours instead of buying it? is that your way of saying that the car you are offering is also not that good?
Edited by R34_T88_Widebody
i didnt know it was in such bad condition. i msgd him about the swap before i received the pm about the cars condition.
my car has a fresh coat of paint on it mate.
who are you to say sh*t in this thread if you have nothing to post thats relevant to the topic? i guess not so F**k off tosser. go start sh*t and get your post count up elsewhere.
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
