As stated guys i have my beloved wheels for sale. As i have no skyline anymore time to get rid of these. Pic of wheels on my old car attached. I am looking for $2100. PM me or call me to make an offer 0415 158 777.
Jon :ban:
PS sorry i cant attach the pic but if u want the pic post ur email and i will send it to you.
THESE RIMS WHERE BOUGHT FROM OZZY TYRES NOT THE CHEAP VERSION FROM TEMPE TYRES. A FEW PEOPLE HAVE CALLED ME WITH PRICES FROM TEMPE RING OZZY TYRES AND SEE HOW MUCH THEY GO FOR BRAND NEW.
https://www.sau.com.au/forums/topic/115146-19-inch-gestalts-for-sale/
mate r they gestalt 1 2 or 3s? becuase i have attempted to put a set of gestalt 2s in 19s on my r33 and they didnt clear my front calipers.
very interested but i need u 2 confirm if they are an offset which allows them to fit or something.
email me pics to [email protected]
cheers
cheers
No they are 1's. They should fit on your 33. I had no trouble on my 32. I will confimr it with you. What offset do u need for the r33???
Will send pics to you tommorow all pics are at work.
Thanks
Jon
PS they are listed on ebay another 5 days to go
man im pretty sure they are gestalt 2s hey, but thats good 2s are better then 1s
wat tyres are on them and how much tread is left? and r the rims scratched at all?
I have falkens for the rear almost brand new. Not sure of the brand will check tonight. Yes confirmed they are the 2's.
The front tires need replacing. One little gutter rash that is not noticeable. as long as a staple.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
