Hi,
Is anyone elses boost going up a little more than usual in this current weather state? Mines nearly reaching the +7mmHG, im thinking around 10-12psi.
This is at night of course.
turn your undercar neons off and everything will go back to normal.
Its common knowledge that undercar neons will increase your boost levels, even on NA 4 Cylinder's
https://www.sau.com.au/forums/topic/115155-boost/#findComment-2121048
You will notice more performance at night comming into winter due to the colder dencer air...
This is common for any car... Cause if the air is 10 degres cooler entering the air filter its gonna be 10 degres cooler at the throttle body (allow for some variance of course)...
This in turn will make the turbo sound different and improve performance... But i have seen boost increase under stock control or with a bleed valve....
Us with electronic boost controllers dont see these things happen anymore...
https://www.sau.com.au/forums/topic/115155-boost/#findComment-2121121
I've been told with the avc-r (electronic boost) that it can still spike.
i'm running 1.2bar of boost (17psi) and the guys who tuned it said it could spike to about 1.3bar of boost during cold weather.
https://www.sau.com.au/forums/topic/115155-boost/#findComment-2121213
Haha, my neons are off haha. Yeh i understand the colder air theory, we all did year 12 science. But i would of thought the actuator and the wastegate would of controlled all the increase and ONLY slightly increase the boost. Isuppose thats the way it goes.
Anyways is your car doing it? for those who dont have the SPC SBC ABC PFC PFFFFFFT systems, =)
Edited by arbess
https://www.sau.com.au/forums/topic/115155-boost/#findComment-2121831
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
