hey guys i got an auto 92 gtst with a green label AFM, sumtimes leaving the lights the car stops making power past 3 thou revs, since this is an auto i have to switch the car off and start it again for it to be working fine. my guess is the AFM screwing up, since the things covered with oil, could i be right?? if so how would i clean it without damaging it, got no $$ to buy i new one since i heard they go for around $250+??
cheers guys
https://www.sau.com.au/forums/topic/115172-what-do-you-use-to-clean-your-afm/
  • 3 weeks later...
i cleaned mine last weekend
using contact cleaner
i dunno about not cleaning it well, there was a stack of dirty liquid coming out of it, and the mesh on both sides was left shiny
didnt affect my fuel economy any though
I'm quite adamant at doing this myself... the filament inside the AFM looks REALLY REALLY fragile and sparying brake cleaner/carbycleaner etc onto it doesn't sound right.
Carby Cleaner might come out as a mist, but brake cleaner comes out in a jet-line.
Any thoughts?
Any thoughts?
As an aside Stan, six years ago the 'accepted' means to clean your AFM was to remove the mesh and get stuck in with a cotton-bud and some metho :nyaanyaa:
And I've used the jet-line BrakeKleen three times now, all good. ;)
Go with plastic safe electro contact cleaner. Do not use carb clearner, it will leave a oily layer on the sensor.
no-one on this forum really knows for sure, that's the sad state of affairs.
I've used brake cleaner, but *apparently* it doesn't remove any carbon deposits (worked fine for my afm though)
some people suggest using carby cleaner because it also removes carbon residue. other people claim this is bad because it leaves residue. BUT no-one can explain *what* the residue is, and how it is *bad*, so go figure!!
look, brake cleaner or electrical contact cleaner are both basically the same thing, they are alcohol based, and probably better than mineral based degreasers which can effect some fragile sensors etc. I'd try using them, and if you are having a specific problem and they don't fix it, try replacing AFM's
Using Oiled pod filters (HKS powerflow / foam filters) tends to kill AFM's because the oil coats the afm contact causing bad things to happen.... so if you have one of these, best change it to something else.
Edited by MerlinTheHapyPig
This is the specs for the NF contact cleaner, about the best one you can get and the one i'd get:
CRC NF Contact Cleaner is a technically proven stable, inert high purity cleaning solvent, designed to meet today's environmental challenges. This new improved formula is chemically stable, evaporates rapidly, has no flash point and leaves no residue.
Use NF Contact Cleaner for cleaning: PC Boards, Edge connectors, motor and motor controls, contacts and relays, metal switches, sensors, flux removal.
When CRC NF Contact Cleaner is used on lubricated rotating, sliding or stepping contacts it is recommended to apply CRC 2.26 to replace lubrication.
Revolutionary Precision Cleaning Solvent.
Instantly removes grease, oil, dirt, flux and other contaminants.
Chemically stable, non-conductive, non-corrosive.
High purity formula evaporates rapidly and leaves no residue.
Strong cleaning action for removal of flux and oils and others contaminants.
No Flash Point. Non flammable.
Does not contain CFC 113 or Methyl Chloroform.
May be harmful to some plastics, e.g. A.B.S. Pebax 2533, Polystyrene etc. Test on small area before using.
This is the more commonly found co contact cleaner, and I'm sure would probably be just as good:
CO Contact Cleaner Plastic Safe Formula is a technically proven, stable, inert high purity cleaning solvent. Non-corrosive, non-staining, rapid-complete evaporation - contains no lubricants. Removes light contaminants, dust, lint, atmospheric/oils, finger prints, moisture from precision electrical/electronic equipment where lower-flashpoint solvents may be used. Leaves no residue to increase resistance. Use as a touch-up supplement for vapour degreasing.
CO Contact Cleaner Plastic Safe Formula used in a planned maintenance programme will eliminate carbon deposits or contaminants that hold moisture and cause corrosion or arcing. An increase in resistance will indicate the frequency of re-application.
Use CRC CO Contact Cleaner for cleaning: Relays, switches, circuit breakers, alarm and signal systems, printed circuit boards, connectors, generators, contacts, laboratory and test equipment, video heads/drums, terminals, plugs and jacks.
It could have been running lean before. Dirty AFM = understated airflow = less fuel input relative to actual amount of air = running lean.
Clean AFM = airflow stated correctly = more fuel input relative to actual amount of air = using more fuel = worse fuel economy.
Maybe?
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
