Hey how are you, I've been looking for the same thing for quite a while, & as far as jap bolt on's are concerned there is stuff all available. There is an Apexi 1 that nengun sells I believe as stated above but it's only got a 2.5 inch inlet. Kakimoto did make one, but it's discontinued much to my dissapointment. The only other alternative I know of is Reinhard, but they're meant to be 95 dB according to 1 place that sells it even when they are silenced!!
If you really want a twin tip muffler that's not too loud however, go and get a custom system, I'm about to be doing the same myself as I've been searching for several months & apart from what I have mentioned have found nothing. So I wouldn't spend too much time searching if I were you.
Mines one of two that were im ported by option 1 garage, I got it a couple of years ago when the "Canon" Muffler phase was at its peak, but I wanted a twin system, took me ages to find mine.
Its a Fujitsubo. I beleive this model is now discontinued though :devil:
Edited by MintR33
heres mine, pretty sure its an X-Force ..
3" inlet.
although i am going to have to find a way to run 2 of them..
edit: this tip is now a gold colour since its stainless
Edited by Craved
I'm planning to mod a stock R33 muffler. Chop off the in and out pipes, then weld on bigger pipes, open up the muffler, and convert it into a "straight through" kind of design using baffled tubes.
Making it fit the Nismo 3" catback section will be tricky, methinks!
Currently looking for a used muffler, so I don't have to cut mine up!
Its a Fujitsubo. I beleive this model is now discontinued though :)
Yeah I had heard that they had made 1, but couldn't confirm it.......... bastards! Well it's cost them a sale cos I would have bought one of those, that looks just nice. Is it twin 3 inch?
Cheers guys.
Dam Electro that is not what i wanted to here :)
MintR33 that is hot, i would love something like that pity it is discontinued.
I wonder if i could source a 2nd hand one.
Yeah sorry mate, but at least you don't need to go through all the crap of trying so hard to find 1 you could cry :O .
By the way I doubt you'll find a second hand twin Fuji since as MintR33 indicated they are very rare. Not unless someone happens to be upgrading to a 3.5 inch system that has 1. Sorry again.
I'm going to be getting a custom 3 inch system with JunBL Muffler & custom tips, will show you what it looks like when it's done. Will probably be a couple of weeks.
  • 4 weeks later...
Same here
Im looking for a twin outlet exhaust system. The drift brand that autobarn advertise in HPI have one, and the other that i have seen is the Reinhard (look damn cool though). Ive got a sedan and have an x-force 3in system with a barrel muffler, little did i know when i bought it, that it was the "angled" type and looks a bit strange sticking out to the side, as it sits too close to the bumper :O. So im looking for a nice dual outlet muffler like the reinhard - dual separate mufflers, 3in inlet -> 2 x 2 1/2in - 3in barrels? Wonder if that decibel rating is just the muffler or a catback system?
cheers
Evil
I got rid of my 4inch cannon HKS race muffler, for a custom 3inch straight through sports muffler. I had it custom made, its gotta be one of the biggest bodied mufflers going!! Id say 50cm x 35cm x 25cm, its 3inch straight thru, with twin 3inch tips. Knocked about 20-25 decibels off my GTR, Quick fit Mufflers made it up for me, took about a week..
Edited by mazgtr
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
