Hey people, got a fair bit of items for sale for those who want it. Ranging from interiour, rims, springs, etc. id like to sell the interiour in one go, not individually.
Interiour: would like to sell all complete without steering wheel $600, with steering wheel $1000
Series 2 front seats, both passenger and drivers
Series 2 rear seats
Rear trims
Glove Box
Centre Light
Full aircon system, including new condensor
Boot lining
SRS airbag steering wheel (very expensive and hard to come by)
Rear seat belts
Full carpet, great condition
Front and rear matts
Springs: Theres to sets, meaning 8 springs so $500 per set
S.W.I.F.T springs (one of japans greatest springs ever hand crafted and highly scrutinized and tested)
front - 13kg/mm
14kg/mm
rear - 15kg/mm
16kg/mm
Rims: $1200 with no extra tyres or $1600 with the extra sets
White (pearl) AVS model6 rims $1200, with good tread currently
Front 16x215x50series (GTR offset)
Rear 16x225x50 series (GTR offset)
Also have 8 or more extra sets of tyres for these rims
please call 0404873163 if u would like anything, or simply pm me
thanks
nathan
https://www.sau.com.au/forums/topic/115200-r33-series-2-gear-for-sale/
^^^^ thanks dude, hahahaha, yeh im in adelaide.........
as to those whove sent me pms, everything is in great condition, i hate having anything looking crap, but id like to sell all my interiour in one go, not in peices........sorry
also got another set of rims for sale,
il post sum pics soon, sorry guys.....been repairing my 33 at the moment, if i havnt been too up to date, still got everything.......internets also screwed up
please re-send all pms if u still want stuff, il get back to u as soon as i can.
sorry again,
the other rims are polished alloy, 17x235 front
17x255 rear (with dish) no major offset, still look nuts.....brand new tyres, bridgestone potenza's
dont have an antenna.....my car was fairly stripped wen i imported it, coz its a track car, then i got interiour for it.....not worrying about antenna, so i dont have that sorry man
the mats are 3 peice, one long one for the rear and 2 fronts...great condition no tears at all or holes...its all up for grabs, sumone please take the stuff coz i dont need it and its only taking up room in my shed which could be used for more important stuff
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
