ok i've been told to chop off the tube vaccum from the engin that goes to the black box that converts to digital data and sends info through elextrical wire to the dahs or the stock boost gauge and then with the thinner hose that autometer supply stick that into the tube (even though its way thinner and then seal the thicker hose around the thinnner one with a cable tie of some sort, is this the way to do it ? i though if i go from a thick tube to the thin one the reading will change ?
Originally posted by JET-33
i did mine the other week...
theres a tube from the plenum to the stock bov (which i dont use) so i tapped into that...but u gotta make sure u block it from other tubes and u should get a proper reading...i do...
il take a pic tomoz or sumthin if u want
if you can take a photo that'll be great
****ing just spent 30mins tracing the wire for my alarm siren, the dud ewho did it drilled a hole to just behind the driver side wheel and then up into the engine bay somehow and i got through the first hole but couldnt get any further, grrrr covered in grease for nothing LOL oh well looks like ill drill my own hole in the firewall
man ur doing it the hard way... i am assuming that its similar to the RB20 on an R32
im actually in the middle of making up a proper install guide for ppl to put on my site... for now i'll give u a quickin.
this is a plug leading thru the firewall to where ur right foot is... just above the accel pedal.
EDIT**
webspace issues... couldnt upload the pics...
i quickly made this for u in exel... i dont know if it will help with the R33 but for a reference... (ps it took me 2 hours lol as i knew nothing about what i was doing and ended up actually removing the dash cause i thought u could just plug it from a hose leading into the original cluster guage lol)
:P wont let me attach a exel sheet and i dont have winzip... only winrar
try downloading this
http://members.optusnet.com.au/japimports/...e%20install.xls
Guest INASNT
nark
the r33 and r32 engines bays are slightly different, in the r33 u can pass the tubes for the boost gauge through near where the ecu is, its the only entry point through the firewall. Theres a rubber grommet there, either remove it or cut a hole for the tube to pass through.
Just tap the vacuum line that the stock gauge gets the signal from with a T piece and plug the line for the autometer gauge to that. Its near the top left of the engine bay off the top left of the intake plenum.
ended up drilling the bracket holding the guage into the pillar (too difficult mounting on dash coz of angle) but looks great, battery went dead so gotta wait till morning to fire her up witha jump start, ended up running tubefrom ehind the indicator on the driver side and up into the engine bay ;)
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
