ok i've been told to chop off the tube vaccum from the engin that goes to the black box that converts to digital data and sends info through elextrical wire to the dahs or the stock boost gauge and then with the thinner hose that autometer supply stick that into the tube (even though its way thinner and then seal the thicker hose around the thinnner one with a cable tie of some sort, is this the way to do it ? i though if i go from a thick tube to the thin one the reading will change ?
Originally posted by JET-33
i did mine the other week...
theres a tube from the plenum to the stock bov (which i dont use) so i tapped into that...but u gotta make sure u block it from other tubes and u should get a proper reading...i do...
il take a pic tomoz or sumthin if u want
if you can take a photo that'll be great
****ing just spent 30mins tracing the wire for my alarm siren, the dud ewho did it drilled a hole to just behind the driver side wheel and then up into the engine bay somehow and i got through the first hole but couldnt get any further, grrrr covered in grease for nothing LOL oh well looks like ill drill my own hole in the firewall
man ur doing it the hard way... i am assuming that its similar to the RB20 on an R32
im actually in the middle of making up a proper install guide for ppl to put on my site... for now i'll give u a quickin.
this is a plug leading thru the firewall to where ur right foot is... just above the accel pedal.
EDIT**
webspace issues... couldnt upload the pics...
i quickly made this for u in exel... i dont know if it will help with the R33 but for a reference... (ps it took me 2 hours lol as i knew nothing about what i was doing and ended up actually removing the dash cause i thought u could just plug it from a hose leading into the original cluster guage lol)
:P wont let me attach a exel sheet and i dont have winzip... only winrar
try downloading this
http://members.optusnet.com.au/japimports/...e%20install.xls
Guest INASNT
nark
the r33 and r32 engines bays are slightly different, in the r33 u can pass the tubes for the boost gauge through near where the ecu is, its the only entry point through the firewall. Theres a rubber grommet there, either remove it or cut a hole for the tube to pass through.
Just tap the vacuum line that the stock gauge gets the signal from with a T piece and plug the line for the autometer gauge to that. Its near the top left of the engine bay off the top left of the intake plenum.
ended up drilling the bracket holding the guage into the pillar (too difficult mounting on dash coz of angle) but looks great, battery went dead so gotta wait till morning to fire her up witha jump start, ended up running tubefrom ehind the indicator on the driver side and up into the engine bay ;)
    • Awesome mate, sounds like an awesome car! My 33 has the 400R/Nismo front and rear bumpers and side skirts. They're in terrible condition though so I either need to fix them up or toss them and get new, standard bumpers and skirts. I wish the Nismo stuff was FRP not fibreglass as they're always one nudge away from complete destruction!
    • Thanks mate 👍 The car was brought into the UK by a USAF mechanic until he was stationed back to the US, one owner later I bought her back in 2009. Luckily the only corrosion was on the sill seams, so once taken back to metal and treated and sealed all ok, I then undersealed the car myself and check yearly and treat any corrosion which to be honest is zero. She's garaged most of the time and hardly ever driven in the rain, but as you say most are rotten unfortunately, I was lucky in finding her as she was and still is in excellent condition.
    • Stunning car.  Looks amazing!  You're in the UK?  How the hell do you stop your car rotting away beneath you?  British cars are the WORST I've ever seen in regards to rust.  Some of the cars SR Autobody have done are borderbeyond saving.
    • not a date code? or a foundry code?
    • I have up to date pics of the engine build and turbo conversion over on my instagram @skpro_jects if you want to take a deeper look.   Basically the exhaust manifold is straight bolt on and the ports match (they arent any smaller than a 25 or 26 head).    the intake ports are different shape so the 20/25det manifold will bolt up but wont match properly or seal. You will need to port match using the 25det gasket as a stencil. Personally i ran the entire stock 20neo intake setup and have configured the swirl valves and torque valve to work based on my custom parameters to help with off boost response and spool. But this is using a standalone aem v2 ecu. The stock 20det ecu wont be able to control them.
