I have an r33 gtst. It has a-lsd (i have the lights on my dash) and it does appear to be working because the light does come on when I lose traction.
I have a bottle of oil in the right hand side of my boot.
I was wondering, how do I change the fluid in this system and what fluid do I use?
The reason why I am wanting to do this, is to hopefully make it more responsive.
Surely someone with an r33 or r34 gtr vspec has done this before?
Cheers
https://www.sau.com.au/forums/topic/115298-a-lsd/
I also have an A-lsd, and i'm not 100% sure on the process of removing the old fluid and replacing.
One would assume there would be a drain plug somewhere probably around where the lines come down to the diff, and possibly a filter of some description? Maybe not.
I know to replace the fluid you are to use automatic transmittion fluid.
You might be best off pm'ing paulr33, I know he has an A-Lsd and seems to know a bit about them, so i'd give him a go.
https://www.sau.com.au/forums/topic/115298-a-lsd/#findComment-2136798
I was actually inspecting the unit today, and i seemed to notice a bleed nozel sorta like the brake caliper.
Also, I don't think the fluid is ATF. My jap owner seems to have put atf into the tank on top of the existing fluid. It just floats ontop of the other stuff (which is black). i'm guessing it uses attessa fluid?
I remember looking at a schematic diaqram for it before and it also uses oil pumps and stuff too.
https://www.sau.com.au/forums/topic/115298-a-lsd/#findComment-2137682
Now, gtrs come with 2 way mech diffs. Vspec comes with these diffs, so surely they must be better? Doesn't feel like it to me though. There are a few more things that I have observed:
My car has got the vspec diff with the finned cover.
I have the fluid tank in the right of the boot
I have the slip/a-lsd lights.
So I guess I could say that it's pretty certain I have A-LSD.
If I drop the clutch, the Slip light comes on and both wheels do spin.
My issue with the diff, is it seems to be quite lazy. I'll elaborate on this further.
I've been in a car with a fresh viscous lsd. I am 100% sure that it was a fresh r33 viscous, because it was on a friend's car (definitely wasn't a mechanical aftermarket). He had it replaced by warranty when his diff died. It was actually quite tight and quite nice. e.g. if you give it a bit more gas when going around a corner, you could feel it go lock lock lock lock lock (sorta like a mech diff, but nowhere near as tight or as brutal).
Now, my A-lsd seems to be quite comfortable, and not what i'd expect of on a vspec, considering it is suppoed to be better than the normal gtr which did come witha mech diff. I seem to have to give it quite a bit when going in a tight circle before the slip light comes on. it deosn't really seem to lock that much either.
Now, I have changed the diff oil to new oil. didn't really do much.
My next thought was that maybe the fluid in the cylinder needed changing. It's strange. My jap owner seems to have tried to top it up with ATF. But the ATF is just sitting on top of the orignal fluid. The ATF looks quite obviously red. The other fluid looks black. So i'm not sure what eh orginal fluid is. Is it attessa fluid?
Do you know how to change the fluid? like do you have anythign on it?
I have the r33 engine manual and the r32gtr full car manual, and neither have it.
https://www.sau.com.au/forums/topic/115298-a-lsd/#findComment-2137773
I'm fairly certain it is ATF you use in there. By saying that the fluid you have placed on top sits on top of your black fluid, says to me that you are most likely in need of a complete flush.
As for the A-lsd being lazy, well it will only lock when it needs to.
A tight new viscous lsd will work when the vanes in the lsd casing are working correctly and are locking both wheels when it is needed.
The A-lsd works in conjunction with your ABS wheel sensors and the A-lsd computer works out when one wheel is spinning more than it should be compared to the other wheel and vehicle speed (as is to my knowledge) and locks the diff where necessary.
You said that you have to give it quite a bit while going in a tight circle before the slip light comes on. Well it seems like its working properly then, as ideally when turning, especially on tight corners, you want your car to behave like it has an open diff (read: a-lsd not locked), and as soon as you give it too much, or one wheel looses traction both wheels should lock, which sounds like what is happening with you?
And again, with you saying it doesn't seem to lock that much, well it all comes down to driving style I guess? And various other factors like weather, suspension and tyres.
If you say its not locking much when you're flogging the car everywhere, then that may be a problem, but as far as everyday driving goes, you should almost probably never see that slip light come on.
Mainly during spirited driving, or maybe if you take a corner too hard and go into some oversteer, or your exiting a round about in the wet and give it too much gas. These are the times you'd expect the diff to lock and it'd be doing its job.
If you're still unhappy with how the a-lsd is performing after a fluid change, i'd get it checked out by someone who specialises in their operating parameters (not easy).
As for information on changing the fluid, i'm sorry I don't have anything, i've only got the engine manual myself which doesn't seem to have the info.
You might want to check out the downloads from these guys, they'll probably have it, but they charge: http://www.jpnz.co.nz/
Goodluck
Edited by insu
https://www.sau.com.au/forums/topic/115298-a-lsd/#findComment-2137954
I had my ActiveLSD fluid changed this week. My normal mechanic done it and im pretty sure its the same as any other LSD fluid change. He didnt mention anything extra special and knew it was a vspec diff.
The ALSD or Vspec diff isnt a hard locker diff, like a mechanical one.
Once engaged (slip is on) its a much more responsive and snap lock.
It's not like a mech clamp lock and it wont ever do rerp rerp rerp when turning corners like a mech diff does.
If I'm cornering hard and I see slip come on, I usually don't feel any difference in the car. This is the computer sorting out the splitting in real time to prevent that exact, rerp rerp rerp from a mechanical diff.
The Vspec or ALSD is basically a mech lock diff without the nasties associated with a mech lock, such as the rerp rerp repr or crabwalk affect.
I didnt have any problems with my ALSD system or fluid but since Ive applied the PowerFC patch/fix its been working 100% more so Ive sinced organised a fluid change as its on 140 on the ODO so I thought it was time for change of fluid. Other than that it absolutely rawks.
Also I dont believe this was an option for ER34 skylines. I think it was only for R33 GTST known as the GST25TML spec
https://www.sau.com.au/forums/topic/115298-a-lsd/#findComment-2138047
Paul, I'm not sure if we're talking about changing the same fluid. I changed the diff fluid, i.e. the drain bolt on the bottom and fill plug on the side.
The old fluid wasn't really dirty. I put in motul lsd oil. this is just used to lubricate the diff.
What i'm unsure about how to change, is the oil in that tank in the boot. This is part of a separate system. this system has an oil pump, which pumps fluid to make the diff lock I bleieve?
The original fluid appears to be black. The jap owner topped it up with some ATF, which is red and just floating on top making me believe the proper stuff is something different.
https://www.sau.com.au/forums/topic/115298-a-lsd/#findComment-2138062
Unfortunately, i'm not in melbourne, but thanks so much for all the advice.
I guess i was expecting it to be different. Everyone seems to say a tight tight mechanical diff is the goods. I was just thinking that if even my friend's brand new standard viscious does that chirp chirp (crabwalk) thing slightly, i was thinking that this might.
But now i understand. I suppose the best way to think about it is like ABS. Obviously the wheels aren't going to do a full lock like a non abs car.
https://www.sau.com.au/forums/topic/115298-a-lsd/#findComment-2138065
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
