Well after a quick visit to Perth I'm back in the land of Trabants and Ladas. For those I missed out on catching up with in Perth my apologies.
I would like to send thanks to Ant, Hanson and the Xspeed team.
As some of you know, my build-up has been long and drawn out stretching over 2 years now. The past is the past, but the important thing is that the work and the dedication that Ant Scali put into my R is certainly very much appreciated and definately beyond what would be considered "just doing his job". Likewise the build-up pics supplied by Hanson and Jamie along the way and the regular emails and updates were very much appreciated.
Some may accuse me of being a "cheque book tuner", but unfortunately when you live and work in another country you either give up your dream or you rely on others to help you out. All I can say is that it wasn't a cheap dream to live, but the outcome has been well and truely worth it to me. The torque, response and braking package that we've managed to put together brought a smile to my face every time I drove my car over the last couple of weeks. There are a few small "tweaks" left to do (slight revision of intake cam specs and more work on cam timing), but essentially I've got the R that I always wanted.
To the other workshops (particularly Ken at Hyperdrive and Roy at C-Red) who gave unbiased input and advice along the way, thanks also.
Cheers
Gav
Setup is:
N1 block
HKS 2.8L crank
Nismo bearings
Pauter rods
ATI crank damper
HKS pistons
GT-RS low mounts at 28 psi
HKS bridged manifold
HKS hard piping induction kit
Apexi 136mm IC
Greddy plenum
HKS fuel rail (twin entry, single return)
HKS fuel regulator
HKS 680 injectors
Nismo intank fuel pump (direct power feed)
HKS step 2 cams (264IN, 272EX)
HKS guides, springs and retainers
HKS timing belt
HKS cam gears
HKS metal head gasket
Ported head
Trust oil pump
N1 water pump
HKS dumps, pipes and exhaust
PFC D-Jetro
Blitz dual solenoid BC
Splitfire coils
HKS Twin Power CDI
HKS twin plate clutch
GTS4 diff centres front and rear (shorter ratio than GT-R)
CSC 354mm 4 piston brake kit on the front
Edited by Gav
I think he did thank Jamie, moron.
Anyways, great to see your car finally out at the track day Gav. The car is just amazing.
Can't wait to see what time this puts down with an upgraded box.
Edited by [SOARER_TT]
Great to hear that the car is back on the road Gav. I bet it will be hard having to wait untill you come back to have another drive.
Did the bridged manifold fix the turbo shuffle problem you originally had with the GT-RS Turbos?
Cheers, Dror
Cheers, Dror
Hi Dror
the bridged manifolds certainly did reduce the compressor surging or "choo choo train" effect, however it is still present at neutral manifold pressure (i.e. sitting enough boost to counteract engine vacuum).
To be honest with the much torquier engine, it is an area of engine load that really isn't used that much anymore. Highway cruising is now very easy off boost. Spool-up (unless in 5th gear) is generally fast also and you pass through the "shuffle zone" pretty quickly.
Have to admit the extra torque and short diff ratios makes you pretty lazy around town as generally I only use 1st, 3rd and 5th gears now.
Pics added to first post
Looks good Gav....top stuff.
that drama with the crank got sorted i hope.
If ya want a squizz at how ours is progressing see link.
http://www.skylinesaustralia.com/forums/in...howtopic=114653
Edited by DiRTgarage
Thanks Paul - have certainly been watching your progress carefully.
I'm still in a couple of minds about how good the GT-RS terbs are compared to the 2530s. I did a back to back drive with an R33 running a Jun 2.7L kit and 2530s. Although the dyno graphs showed the 2530s coming on earlier, the real world driving comparison between the 2 was very similar. The GT-RS terbs certainly seem to respond well to high boost levels. Next step will be to revise the inlet cam (change to longer duration 272) and play some more with the cam timing. Rev limit is still set fairly low to 8200 for the moment, however there is probably no reason why this can't be lifted given the supporting hardware.
    • Oh and my rear arms may need some attention too.
    • Bushings are almost done. Check the date stamp 😂 these are likely the original bushings with 27 years and 243ks on them.     Was too dark to get a pic of the worst one.
    • Porous blocks are a known issue on something like a Porsche M96, it's not really something I've ever heard of on an RB26. It's possible what people thought was a "porous block" was really a cracked block that they just didn't spot the crack on.
    • This is a controversial subject really, the whole power vs fun thing I mean And this is the main reason I got back into a MX5 Of the last few notable daily cars I've owned whilst I have frequented SAU R33 GTS-t: fun, but because I'm a idiot I modified well past a reliable fun car and ended up hating it, although that was my fault because I tried to have a daily cruiser and race car all in one, the family called it the sometimes car, because sometimes it was working, sometimes it was broken, gladly sold it NB MX5: brilliant car, thrashed the Bejebus out of it, but, again, was stupid and deleted the air con, power steering and stripped the interior out, whilst still fun, and reliable, and super cheap on consumables, it was not a fun place to be going on long cruises, I did love it, but basically every family member hated going anywhere in it, sadly sold it 2015 WRX STI: soulless thing that looked like your average Kia sedan and had that horrible boxer engine with glass ringlands, the family did like it though, that thing was one of my stupidest purchases and I still regret it 2017 Toyota 86: 😪 if I didn't crash it, I would probably still have it, it was a fun little thing, even with that horrible boxer engine, the family did like it, the only reason I didn't get another 86, or, BRZ was the boxer engine, I should have learnt after owning the STI, but I'm a idiot VX SS: great cruiser, fits the whole family, and was fast as.....in a straight line, but a big fat thing, so no enjoyment throwing it around corners, the family was unimpressed with the whole boganness of if, but they did admit it was a comfy place to sit on long cruises As for the NC, I feel it is perfect for what I want, or need out of of a car, whether I'm cruising the Hwy, back roads, twisties or peak hour traffic, the Mrs doesn't mind driving it either, or cruising in it as well, although she does bump her head of the roof nearly every time she gets in, which is farking hilarious, and the kids love taking it for a thrash as well So basically, I've had constantly more fun, and way less headache and heartache, both on the track and on the street, in low powered cars,  go figure.....LOL One thing though, the Mrs has stated that the cams have made the exhaust sound much louder, which they have, but it doesn't bother me, in fact, I actually like it, but, to negate any future comments from the Minister for War and Finances I may look at some changes to the rear muffler set-up to drop the volume down a tad to appease her when we are out and about in it
    • You will need to extend the turbo inlet pipe somehow, which could/might be done with silicone/rubber pipe, but might need steelwork, depending on your intake. And you will need to change the pipework on the outlet in teh same way, but this is more likely to need steelwork.
