Looking for advice on quiet (under 98 Db drive by at full throttle, on track, measured trackside) systems. I have tried a Trust / Greddy Power extreme II which made 102 Db, a doubling of the perceieved noise allowed, so no good at all, and nor is an HKS Hiper Silenced, with a similar noise level. It's the fairly large turbine size I am running, I guess, that's the issue. The exhuast that's on it is a bit ropey, and mild steel. No ID on it, obviously commercially made, but I have never seen one like it before, it came on the car as bought. I need to have a replacement for it soon, and on the new engine about to go in the turbine housing will be bigger, the capacity bigger, and a lot more cam and revs.... Do I need to make a custom system? Do you have noise issues in Oz? How do you meet them without killing too much power?
Thanks.
Holy crap...102db? I have an external gate and i dotn get pinged when at the track, i think they are checkign for 95dB???
What turbo setup are you running? ID be tempted to go twin system, with twin mufflers. You can pack it up nice and tight to the underside, you can the flow benefits of a 4" system and you can share the gasses accross two mufflers
..LOL well the theory sounds good on paper :)
If you wanna make it quiet, twin system is the way to go. All the gains... none of the noise
And its gonna be a custom job and pricey
All the big HP GTR's here in melb are doing it
Twin goes ok into the GTR floorpan aswell.
Not sure on the GTS-t layout, but it couldnt be any worse :)
Im doing the same aswell
I believe they mean from the cat two pipes run towards the rear of the car. So two pipes and two mufflers. I believe if its 2x 2.5" that equals to about one single 4" pipe?
I've considered doing this as well but can't imagine it being too cheap.
Since we're on the topic of exhaust (sorry to OP, don't mean to hijack) is a 3.5" fine for a GTT? Or should I just got 3"? I'm afraid 3.5" might be 'too' big?
siba33 - Twin... wether that be a single dump or twin dumps (single or twin turbo) and then have it twin all the way to the rear.
With a cross-over pipe somewhere along the line.
2 cats (smaller obviously) and then 2 or 4 mufflers somewhere along the system depending on whatever you choose with the exhaust shop etc.
No such thing as "too" big for a turbo car IMO.
You could always get it made out of titanium.
I have a Fujitsubo system. Not sure what it's called but I was at a shop once and there was a car there with it so I said I want that one and they got it for me.
My system is 3" from the turbo back (GTT) and is not restrictive. I have 255rwkw at only 0.9 bar of boost from a highflow turbo so I think that proves it's lack of restriction. 3.5" is just louder if you ask me but in terms of power you can't relly go wrong going bigger.
Anything that's 3.5" or over is a bastard to shut up. In my .sig I have an 100mm exhaust that flows, for sale, but I've
never measured it trackside on full noise. It's 95db @ 3500 no load, (with cats/resonator/muffler)...
On the back of a napkin:
2 x 3" exhausts (ok, 2.82") should flow as much as a single 4"
So if you could find a 3" exhaust configuration that was 95dB on full noise, 2 of them _should be_ 98dB.
Some things to think about:
* are most of your competitors within the 98dB limit? If not, how loud are they on full noise trackside?
* you'll probably only get pinged if you're noticeably louder than other cars in your class or your competitors complain.
* are other car noises (induction/tyre/gearbox/etc) included in the level? If not, how are they eliminated?
* if you're in with a bunch of other cars, there's no way they can measure just you :D
* if you're alone in front, button off past the measuring device
I've heard plenty of racecars that are louder than 98dB (this seems to happen a lot with rotors
and smaller-capacity engines). I've only ever seen one car get chucked off the starting grid
because it was too loud, but I've seen a few get pinged because competitors complained.
There are a few genuine competitors on this forum, might be worth
PMing them for their experiences as threads can sometimes get lost in the noise...
I'd probably try building a twin 3" system, then add muffling till the competitors stop complaining.
Regards,
Saliya
Edited by saliya
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
