Looking for advice on quiet (under 98 Db drive by at full throttle, on track, measured trackside) systems. I have tried a Trust / Greddy Power extreme II which made 102 Db, a doubling of the perceieved noise allowed, so no good at all, and nor is an HKS Hiper Silenced, with a similar noise level. It's the fairly large turbine size I am running, I guess, that's the issue. The exhuast that's on it is a bit ropey, and mild steel. No ID on it, obviously commercially made, but I have never seen one like it before, it came on the car as bought. I need to have a replacement for it soon, and on the new engine about to go in the turbine housing will be bigger, the capacity bigger, and a lot more cam and revs.... Do I need to make a custom system? Do you have noise issues in Oz? How do you meet them without killing too much power?
Thanks.
Holy crap...102db? I have an external gate and i dotn get pinged when at the track, i think they are checkign for 95dB???
What turbo setup are you running? ID be tempted to go twin system, with twin mufflers. You can pack it up nice and tight to the underside, you can the flow benefits of a 4" system and you can share the gasses accross two mufflers
..LOL well the theory sounds good on paper :)
If you wanna make it quiet, twin system is the way to go. All the gains... none of the noise
And its gonna be a custom job and pricey
All the big HP GTR's here in melb are doing it
Twin goes ok into the GTR floorpan aswell.
Not sure on the GTS-t layout, but it couldnt be any worse :)
Im doing the same aswell
I believe they mean from the cat two pipes run towards the rear of the car. So two pipes and two mufflers. I believe if its 2x 2.5" that equals to about one single 4" pipe?
I've considered doing this as well but can't imagine it being too cheap.
Since we're on the topic of exhaust (sorry to OP, don't mean to hijack) is a 3.5" fine for a GTT? Or should I just got 3"? I'm afraid 3.5" might be 'too' big?
siba33 - Twin... wether that be a single dump or twin dumps (single or twin turbo) and then have it twin all the way to the rear.
With a cross-over pipe somewhere along the line.
2 cats (smaller obviously) and then 2 or 4 mufflers somewhere along the system depending on whatever you choose with the exhaust shop etc.
No such thing as "too" big for a turbo car IMO.
You could always get it made out of titanium.
I have a Fujitsubo system. Not sure what it's called but I was at a shop once and there was a car there with it so I said I want that one and they got it for me.
My system is 3" from the turbo back (GTT) and is not restrictive. I have 255rwkw at only 0.9 bar of boost from a highflow turbo so I think that proves it's lack of restriction. 3.5" is just louder if you ask me but in terms of power you can't relly go wrong going bigger.
Anything that's 3.5" or over is a bastard to shut up. In my .sig I have an 100mm exhaust that flows, for sale, but I've
never measured it trackside on full noise. It's 95db @ 3500 no load, (with cats/resonator/muffler)...
On the back of a napkin:
2 x 3" exhausts (ok, 2.82") should flow as much as a single 4"
So if you could find a 3" exhaust configuration that was 95dB on full noise, 2 of them _should be_ 98dB.
Some things to think about:
* are most of your competitors within the 98dB limit? If not, how loud are they on full noise trackside?
* you'll probably only get pinged if you're noticeably louder than other cars in your class or your competitors complain.
* are other car noises (induction/tyre/gearbox/etc) included in the level? If not, how are they eliminated?
* if you're in with a bunch of other cars, there's no way they can measure just you :D
* if you're alone in front, button off past the measuring device
I've heard plenty of racecars that are louder than 98dB (this seems to happen a lot with rotors
and smaller-capacity engines). I've only ever seen one car get chucked off the starting grid
because it was too loud, but I've seen a few get pinged because competitors complained.
There are a few genuine competitors on this forum, might be worth
PMing them for their experiences as threads can sometimes get lost in the noise...
I'd probably try building a twin 3" system, then add muffling till the competitors stop complaining.
Regards,
Saliya
Edited by saliya
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
