A bit of an update for those who are interested in the KKR480 and how it works on an RB25.
The graphs below are for an internally stock R33 (normal head gasket too) with 550cc injectors, pump, Power FC, FMIC and 3-inch exhaust with an aftermarket cat. The owner fitted the turbo himself with a KKR dump pipe. The car was tuned by CRD and a week later ran on the Mainline dyno at the Auto Salon. As you can see the results are very consistent and this is the sort of power most people are getting, with around 19psi boost.
https://www.sau.com.au/forums/topic/115395-new-kkr-graphs/
' date='30 Apr 2006, 11:41 PM' post='2127816']
it aint as cheap as the 699 add makes it out to be.
i do believe, by the time the "special" dump is purchased and installed your looking at approx $1300-$1500
When a GCG hi-flow is around $500 more (bolt on) and far more responsive
The choice is simple
https://www.sau.com.au/forums/topic/115395-new-kkr-graphs/#findComment-2128033
yer i want to know about the 430 as well. i emailed the people but they just spat shit at me about it i dont belive.
asked if this turbo would be suited to my car and if it bolts straight on and not have as much hassle as the 480 installing. Reply;
yes ~ This is a great choose for ur CAR,,,, u will love it~ Just need a bit Mods for Dump pipe ,,,, the Manifold Flange will just Bolt on ,,,, 248 KW at wheel @ 1.1 Bar on R33 GTST with Factory ECU, Intercooler ~~~~~THANKS~~~~~`
Kind Regards
Automotorsports
H.P.A. - Hyper Performance Automotorsports
https://www.sau.com.au/forums/topic/115395-new-kkr-graphs/#findComment-2130392
Kind Regards
Automotorsports
Mate, I don't know who you emailed but Otomoto is the distributor of KKR and we certainly didn't give you that reply. The best result we have seen so far on an RB20 from a KKR430 is just under 200kW at the wheels. On an RB25 we've seen close to 230kW at the wheels. If anyone has done better we'd like to hear about it.
https://www.sau.com.au/forums/topic/115395-new-kkr-graphs/#findComment-2131256
Benhpi, Do you have the graph of the 230rwkw run for the RB25 with the 430?
I'm interested in getting a turbo that give me around that mark of power so that I don't have to go spending big bucks on injectors AFMs full engine management (i have SAFC II).
The other option I've been looking at is a HKS 2530 and they seem to be getting people into the 12.5sec 1/4 region with about 230-240rwkw.
Edited by JaFF
https://www.sau.com.au/forums/topic/115395-new-kkr-graphs/#findComment-2131475
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
