I cleaned out the AAC the other week and had the put the idle screw back in.
Will screwing it in decrease the idle or increase the idle?
Can it only be adjusted while the car is turned off or does the car need to be running while
its adjusted.
I tried to adjusted the idle screw while the car was running but the car would rev up and come back down to the same rpm as prior.
To set the base idle, I think you have to disconnect the TPS first. The revs should drop, and that is your base idle at which you can tune. The ECU does the automatic choke kind of action to keep it alive, or keep it high when cold etc.
I use a consult cable and software, and most of the software allows you to adjust the base idle.
thats correct. disconnect tps, start engine. give it a couple of revs - up to bout 2- 3 grand, then adjust the screw accordingly. clockwise to increase idle, anti-clockwise to decrease idel.
And what is the tps? throttle position sensor? If someone could put up some photos, I would appreciate it. I have a rb25. Ive done everything else except this (cleaned and siliconed up coils, cleaned every sensor with contact cleaner, changed plugs 3 times) and the idle is still all over the shop and it hesitates at about 5000rpm when i put my foot down. It boosts up but something is holding it back.
The idle is all over the place, would that effect performance like I have described?
Well, disconnect throttle position sensor (big black box on throttle body)
start car
rev few times
adjust idle screw
check revs by looking at the dash. Should be 650-700rpm I beleive? Check the sticker under the bonnet somewhere.
turn car off
reconnect TPS.
Timing can be checked using SydneyKid's guide. He wrote it up as part of a timing belt change on a Stagea, look in the model-specific section.
No pics from me! I'm going to work in an hour or so.
Edited by RANDY
Back of the inlet manifold (plenum) there's a blocked off (yellow plastic) hole, and a pipe that runs to your stock boost sensor. Next to the yellow plasticy bit, there is a screw there.
I did a search and finally found the brilliant post that I was looking for!
http://www.skylinesaustralia.com/forums/in...opic=110431&hl=
5000rpm problem has it's own thread somewhere too. Turns out that 90% of the time it's due to hair-line cracks in your coil pack(s).
Aroldtite(sp?) seems to be the best compound for sealing the crack.
silicone? i'd be pretty tempted to do it with glue... silicone doesn't stick as well as i'd like it... fine for plumbing, but I think with heat and metal surfaces it may come loose?
No other ideas, sorry!
It completely misses for half a second to a full second when booting it, right? If so, it's the right problem for the solution, but it could be a number of other things..
Possibly fuel pump leaning out, or ECU retarding timing if you're running higher boost... too many variables. =-[
To clarify how you adjust the idle, i've written the correct procedure below as the RB25 and RB20 procedure is different.
On the RB20DET (as asked by the thread starter)
Make sure the car is at operating temperature.
Make sure ignition timing is 15deg btdc @ 650rpm.
Disconnect the AAC Valve connector to stop the ecu controlling idle.
Adjust the idle screw to 600RPM.
Clockwise will make it decrease (screws in blocking the bypass passage and less air means less rpm), Anti-clockwise will increase the idle (screws out opening the bypass passage more and more means more rpm)
Reconnect the AAC Valve connector and the idle should be approx 650rpm (+ or - 50rpm)
If the idle is higher, make sure the diagnostic screw on the ecu is fully anticlockwise as this can increase idle if not fully anti-clockwise
On the RB25DET (not asked by the thread starter)
Disconnect the TPS connector to stop the ecu controlling idle.
Adjust the idle screw to 650RPM.
Reconnect the TPS connector and the idle should be approx 700rpm (+ or - 50rpm)
    • Nope, still smaller rear, put on the 4inch exhaust and picked up power everywhere, ended up just shy of 800rwhp.   Didn't seem to be hitting any walls either, so perhaps could have pushed for more but all maybes and the fish that got away etc etc.
    • Races cars don't care for VIN either...
    • This could be sold and shipped to the US for many gold pieces. RMS has no say in that. Ask various Western Sydney inhabitants how it works.
    • Ha ha ha, mine loves to spend, all on the dogs (they're our kids, and her spending would likely rival that of some people raising children!) the only benefit is, her spending is tax deductible as she runs a business in the dog industry 😛 The above all means she can spend race car budget quicker than I can. 😛 That and a lot of the things I want are very expensive, and I can be a bit "you want how much for that?!" And at other times overly impulsive. Or I start the w days of research, get to day 1.5 and get really annoyed that no one will advertise actual specifics and it's just marketting BS and I go "well, now I don't want anything to do with that now!" Also I hate paying lots of money for something I can make from $50 in materials. Then I get the shits halfway through making things and wonder why others who just buy parts have more fun... 😛
    • Their 240Z with the RB26 would be a real nice thing to have in a garage to come out for an occasional weekend cruise It's such a cool thing in so many ways Sadly, we have a blue 240Z shell that I walk past every day, just sitting outside a shed at work, it has been slowly disintegrating and falling apart into the ground for the last few years, the owner cannot be found, and I am unable to "claim it" I've been told by work and the RMS, the rust in the body is excessive though, and it has had most of the salvageable stuff, like panels, trim and switch gear stripped off it over the last year or two, work keeps threatening to put it in one of our metal scrap bins, I wish they did though, as it makes Mark sad walking past it
