Guest INASNT
the only a pillar gauge holders autobarn sell are the autometer ones, which wont fit with a jap brand gauge and vise versa.
what type of gauge have u got? if u got an jap brand eg apexi gauge u can pick one up from evo-r in clayton, hey have em in stock and are the trust/greddy brand.
All good. Might even try the autobarn up at the Glen (even though it is very small) and see if they have then. Otherwise I'll go for a bit of a drive. As long as the person that i talk to knows what they are on about
Next question, maybe should start a new thread but I'll try it here.
I want a boost guage that lights up blue like the eluminescent dashs. I'm going to do my dash like that, so i may as well do it to my guages as well.
Any ideas would be great.
Guest INASNT
Originally posted by R31 Skyline Chick
Most gauges come with 'condoms' for the globes, so that you can change them to whatever colour you want.
If there are no blue condoms in the packet, go to Jaycar and buy some.  :P
condoms over the globes dont even come close to the el gauge look.
Arsn
i got the el dash and el apexi gauge on the a-pillar.
if u go to autobarn and buy an autometer a-pillar gauge holder and then get a apexi el gauge u r gonna get screw yourself coz the gauge wont fit the gauge holder properly!
Guest INASNT
Originally posted by Arsn
Thanks heaps for that.
If all goes to plan, I'll head down there on Friday and then should be able to put them in on the weekend.
Do you have a rough idea of the cost of them both?
i got mine over 1 year ago cant remeber exactly.
i got both the el mechanical 60mm gauge and gauge holder for about 300. If u want the electric 1 with the peak hold etc its about 450 by itself!
Evor aint cheap or are the jap stuff, but they work really well!!
Yeah, I just had a look at the apexi site, and they do look pretty impressive.
I figure that if i want the good looking stuff, I'm going to have to pay for it. And the apexi stuff is meant to be pretty good, so i can't see myself backing out of it just because of cost.
I was just thinking that maybe a few different places such as Evo R and Makspeed might have different prices for them and i might be able to save a bit of money.
Thanks for your help.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
