all looks good up to when the power plateau's at about 140km/h..
most graphs i see the car peaks and then drops off rather than plateauing
not sure why that happens
but its been plotted in shootout mode, and the intake temp is the same as the air temp, so the figure is quite realistic in my opinion
ahh thanks for your responses guys..
:D
good to hear that at this stage shes roughly where she's suppose to be..
yeah i agree with finishing off the exhaust first, then follow with fmic and pfc ..
(very very keen for the pfc, hope there is another group buy coming soon :( )
Cheers,
-JD
That’s a pretty good result congrats! I definitely recommend fitting a split dump as it gave me big increase... and I’m hoping to do the same with mine come Christmas time...
-PFC (tuned)
-Splitfire Coils
-Hybrid GT spec FMIC
-Bosch 044 fuel pump
-555cc Nismo injectors
-11psi boost (Turbotech)
What rw/kw figures should I be looking at?
Currently 165rw/kw… all stock except Full 3” exhaust & split dump + K&N
Would a larger AFM make any difference?
Regards,
Sarkis
JD - I am surprised to see your AFR to be so nice. From my experience usually R33s run a lot richer than this. I'm wondering whether your fuel pump is getting lazy. If you go and increase the boost anymore you will see if this is a problem.
I.e. Don't raise boost too much without slapping it on the dyno to check your AFRs
The AFRs are pretty much spot what you would tune them to. Usually the stock ECU doesn't do this..
yeah thanks guys, i am surprised about the afr too..
QRI05E:
I will be looking to do the exact same mods as you after I finish off my exhaust.. (except for turbotech, cause already got 1 )
did you get ur dump from bapmbl ?
cheers,
-JD
Edited by JD-33
Hey JD, I got my split dump and whole exhaust made and fitted by Liverpool Exhausts... at least that way i have 3 years warranty and know who made it... i have truly found them to be the best at price and quality...
Regards,
Sarkis
JD,
I bought a dump pipe and hiflow cat off BATMBL a while ago when I had similar mods to yourself and found a noticeable improvement in power once I had them installed. The stock exhaust is very restrictive, so bang for buck, this should be the next mod on your list.
Speaking from personal experience, I wouldn't go anywhere near the above mentioned workshop if you want quality work done...
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
