Just posting this up for Ben. Apparently was tuned today at CRD, on pulp and ~20psi made 394awkw. Full boost is late 5000ish rpm. Street exhaust, no playing with cam gears yet, more to come later. Will be at the Sports Compact event next month at WSID.
https://www.sau.com.au/forums/topic/115457-600hps-new-rb26-setup/
The car is still a 2.6L with tomei 260deg cams
and forged stuff inside.
The car made the power running a trust street exhaust wich is 3" piping with a 70mm muffler.
also the was running 22psi on optimax.
Last time when we put on our 4" race exhaust we made another 30KW at the wheels, so we'll see how it goes later with that on.
Jim did a great job tuning the car.
The car will be at the track for compact attack but currently the car will not be running as we can't afford a new gearbox just yet.
Thanks to the guys down at Hypertune for doing all the work on the car and installing the new plenum and throttle body.
Edited by 600hp
looking good Ben, we just missed you at CRD.
The T88 is a 33D wich is the smallest T88 they have made and is no longer available.
why not the T88GK, because the GK is rated at 1100hp where as the 33D is rated at 850hp.
The car is very nice to drive arounf the streets.
it makes about 120AWKW before it comes on hard. a stock GTR makes 160AWKW.
The turbo looks like it should make 500 with some other little things added.
as for the bleeder system was done by Hypertune.
No there isn't a V-band flange on the turbine housing.
The car is now an absolute freak to drive now!
Freak as in all or nothing?
Nice to drive around the streets as in off boost or do you always drive around the streets above 6000rpm?
The plenum looks like it makes it more laggy as the lack of midrange is bordering on a joke? BRING BACK THE JUN PLENUM
All up very nice for drags shame you wont run it as plenty of GTR's run 10's with stock gearbox
Edited by SPY
They don't for long though......Nissan 3rd gear + high rpm quick shift = BANG
There are not too many 10 sec cars running stock boxes....Not in Australia anyway. Theo broke 13 boxes to get his 10.78.
Edited by DiRTgarage
Lets not be too critical fo the setup...it is running a 3" exhaust, and it sounds like the tune still has to be fiddled...which if he is goign to be running the race exhaust at the drags and it makes more boost and power as a result of lower back pressure then it makes sense not to spend too much money on a tune for its street setup
Can you tell me what you have done with the air bleeding setup to the header tank?, ity looks interesting, and im curious to what you have done
thats the secret cooling system mod that gtr700 had blacked out in all his photos of his engine.(apart from the extra top radiator hose of the header tank.)
you cant run it like that if your keeping the standard six throttle setup. as it removes the vacume chamber/balance chamber from the inlet.
ie: no vacume take off points.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
