Just posting this up for Ben. Apparently was tuned today at CRD, on pulp and ~20psi made 394awkw. Full boost is late 5000ish rpm. Street exhaust, no playing with cam gears yet, more to come later. Will be at the Sports Compact event next month at WSID.
https://www.sau.com.au/forums/topic/115457-600hps-new-rb26-setup/
The car is still a 2.6L with tomei 260deg cams
and forged stuff inside.
The car made the power running a trust street exhaust wich is 3" piping with a 70mm muffler.
also the was running 22psi on optimax.
Last time when we put on our 4" race exhaust we made another 30KW at the wheels, so we'll see how it goes later with that on.
Jim did a great job tuning the car.
The car will be at the track for compact attack but currently the car will not be running as we can't afford a new gearbox just yet.
Thanks to the guys down at Hypertune for doing all the work on the car and installing the new plenum and throttle body.
Edited by 600hp
looking good Ben, we just missed you at CRD.
The T88 is a 33D wich is the smallest T88 they have made and is no longer available.
why not the T88GK, because the GK is rated at 1100hp where as the 33D is rated at 850hp.
The car is very nice to drive arounf the streets.
it makes about 120AWKW before it comes on hard. a stock GTR makes 160AWKW.
The turbo looks like it should make 500 with some other little things added.
as for the bleeder system was done by Hypertune.
No there isn't a V-band flange on the turbine housing.
The car is now an absolute freak to drive now!
Freak as in all or nothing?
Nice to drive around the streets as in off boost or do you always drive around the streets above 6000rpm?
The plenum looks like it makes it more laggy as the lack of midrange is bordering on a joke? BRING BACK THE JUN PLENUM
All up very nice for drags shame you wont run it as plenty of GTR's run 10's with stock gearbox
Edited by SPY
They don't for long though......Nissan 3rd gear + high rpm quick shift = BANG
There are not too many 10 sec cars running stock boxes....Not in Australia anyway. Theo broke 13 boxes to get his 10.78.
Edited by DiRTgarage
Lets not be too critical fo the setup...it is running a 3" exhaust, and it sounds like the tune still has to be fiddled...which if he is goign to be running the race exhaust at the drags and it makes more boost and power as a result of lower back pressure then it makes sense not to spend too much money on a tune for its street setup
Can you tell me what you have done with the air bleeding setup to the header tank?, ity looks interesting, and im curious to what you have done
thats the secret cooling system mod that gtr700 had blacked out in all his photos of his engine.(apart from the extra top radiator hose of the header tank.)
you cant run it like that if your keeping the standard six throttle setup. as it removes the vacume chamber/balance chamber from the inlet.
ie: no vacume take off points.
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
