hey everyone
heres a list of parts for sale
complete r33 RB25DET engine, with loom, turbo, manifold, gearbox ect OFFERS
xtreme puk clutch, with rb25 flywheel
series 1 headlights $120
series 2 tail lights $ offers
full r33 series 1 interior . good condition $ 500
R33 silver doors - $150 each
R33 series 2 front bar with bottom lip- $ 300- incc black side skirts
r33 5 spoke rims , no tyres ( wll there are but no good) $ 250 painted grey
bonnet latch opener - $ 30
Air conditioning system $ 80
Climate control $ 200
electric window motors , regulators, switches ect, $ 200
Hicas system good working order - $200
Hard shocks with lowered springs aparently tien's $300
good lsd - possibly mechanical?? with rear cradle $ 550
boot lid wioth spoiner ( not gtr) $ 150 silver in colour
front brakes, 4 pot , good condition with lines and rotors and calipers , pads averidge $ 300
rear brakes , black with nissan on them $ 150
brake booster and master cyl, $ 100
rb 25 gearbox conversion , everything you need , consoles ect.
3.5" exhaust fropn dump to diff, $ 70
dashboard no cracks ect including instrument cluster ( 70,00 kms on clock) $ 150
rad support ( small front cut ) $ 300 coond copndition
series 1 grill, $60
folding mirrors $ 100 silver in colour god condition
all other parets avalable
holla and ill post them ecod
cheers :D
https://www.sau.com.au/forums/topic/115509-r33-parts-lots-of-them/
Also interested in the brake setup
Just need to confirm if I am doing a 4 to 5 stud conversion, do i need the brake booster & master cylinder? Also what dimensions are the front and rear rotors? Front (296mmx30mm) and Rear (297mmx18mm) ?????
Cheers
DO NOT TRUST THIS GUY!!!!
I had organised a deal with the above items a week ago. had it all sorted and he sold them to someone else. HOW F**CKING RUDE!
and now hes put them for sale, maybe he will take ur money, then tell u he sold them already.
Just look around and deal with someone trustworthy!
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
