Hello All,
Recently purchased a R34GT-T that came with the Xenon headlights. As you know these lights look great!! :)
The only problem I have is that the high beams look yellow when they are turned on and although it is not anything major I am a bit anal and wish them to be whiter so they blend in with the Xenons.
I pulled the High beam globe out but it was a globe that I have never seen before. Not sure if it is H1 H2 etc, looks totally different.
I hope someone can point me in the right direction and tell me what type/part these high beams globes are.
Pictures below.
Also do you know what type the park lights are for these headlights as well? Pls let me know a pic of the headlights are required!
Great forums here!! :D
Slats
https://www.sau.com.au/forums/topic/115516-r34-gt-t-headlight-globes-highbeam/
Thanks n15m0,
True about the high beamers, may not be worth it. Just did a quick search on google and not much came up for HIR1. What happens if this blows in the future, where can I get them?
I called Autobarn and they said they never heard if the HIR1 globe and when the times comes to replace just conver the connect to a H1 and install a H1 globe in. What are your thoughts?
Also any idea how to get to the parker lights? Do i have to unscrew the whole healight assembly?
Thanks.
Slats
I'm pretty sure they are HIR1, thats whats written on top of the headlight assembly...my left one has been blown for ages...never bothered to replace yet...coz I never use high beam much..
Parkers are piss easy...(if you have small hands like me). No need to remove headlight assembly. Just reach inside the corners where the parkers are..there is a twist knob thingy...turn it and the whole thing comes out with the bulb itself...the battery side might be easier that the air filter side..might have to move the filter slightly to get into it if you have big hands...
replaced mine in like 1min for both..:D
Yeah as much as i dont like to admit it, i have been thinking exactly the same thing. I already had the blue phillips parkers and they still looked really yellow next to the xenons, so i bought some LED globes from Autobarn for like 6 bucks, and they look so much better, very happy with them.
I replaced mine when the headlights were out about a year ago.
I bought mine from Autobahn, they were a standard item.
They will need a very slight modification with a file, but not much.
BASS OUT
  • 1 month later...
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
