Hi All,
My brake pads are just about Fubar, so its time to upgrade!
Now, i was thinking, seeing as i do some sprint/circuit stuff, and intend to do some more this year, i would like something that brakes well...
I'm looking at getting:
Standard Size DBA4000 Slotted Rotors for the front
Machine Standard Rear Rotors
Ferodo DS2500 Pads on both Front and Rear
Brake Master Cylinder Stopper
i already run fresh Motul RBF600 Fluid in the lines, so i don't think i'll need to do anything there...
*If needed* possibly a caliper rebuild...
what are your thoughts on this combo? yes? no?
Anything else i should look at that isn't going to break the bank?
https://www.sau.com.au/forums/topic/115527-brake-upgrade/
  • Replies 43
The brakes on the 33s arnt that bad.With just pads and some decent fluid and master cylinder brace mine has stood up to a summer track day @ wakefield and pulled up time and time again.
So i think that a rotor + pad + mcb + the fluid you will have a decent combo indeed.
Imo the brace works wonders
https://www.sau.com.au/forums/topic/115527-brake-upgrade/#findComment-2127544
pretty sure a 324 will require a 17" wheel.
a rotor upgrade will be heaps better than the 280mm because braking is a function of
1 - torque that is applied to the rotor (increased rotor diameter, higher torque)
2 - rotor's ability to dissapate the heat (larger rotor, more mass, more heat capacity)
3 - caliper itself and ability to consistently provide an even force across the face of the pad
consider that the factory 4 pot nissan caliper is a pretty good thing, just that the rotors are a bit small for dissapating track heat. go the 324s and you will find that you might not even need a caliper upgrade. what may be of worth is a caliper rebuild kit (all the rubber seals) and a bit of time to rebuild the factory caliper... don't think the seal kit would be more than $150 at a guess?
https://www.sau.com.au/forums/topic/115527-brake-upgrade/#findComment-2127609
Yeh, need 17" wheels, and sure using the std caliper on a 324mm rotor may not be as good as running an AP 4 pot, or even a Brembo, but you also have the $1600 in your pocket for other things....and i have found it to work quite well for me the past 5 or so years.
Im actually about to attemptto run a 340x32mm rotor with a tsd R32 GTR caliper...so will see how that goes. Got the rotors foe a reasonable price so figure its worth a try...worst case i may have to hunt down some new calipers if it doesnt work as well as the 324mm rotors...but thats ok as at least i will have the rotors and hats and mods are always easier when you can have small bites at them :)
https://www.sau.com.au/forums/topic/115527-brake-upgrade/#findComment-2127669
Hi All,
You may not necessarily want/need to run the DS2500's on the rear. I have seen a lot of people run 2500 front & 2000 rear. That way you get a less aggressive pad on the back end & never have to worry about getting temperature into the rear.
Also would be worth looking at getting some braided lines for the front end to held banish the muchy brake pedal that Skylines can have.
https://www.sau.com.au/forums/topic/115527-brake-upgrade/#findComment-2128253
You can have a look at mine Tuesday at the track day if you want as I am running what you are thinking of getting -
DBA 4000 slotted rotors up front
Brake master cylinder stopper
Motul RF 600 fluid
But I am running the Hawke pads front and rear, I had them on my GTR and rate them very highly.
My next thing will definately be braided brake lines as the pedal feel isn't that flash atm. . . .
https://www.sau.com.au/forums/topic/115527-brake-upgrade/#findComment-2128488
I'd add braided lines to your list at only $50 a corner done on car if you want, You can't go wrong!
I'd also go the same as JL newton and have hawke pads all round
But as it always comes down to Jas, it's your money
Sounds like a good list otherwise. :(
https://www.sau.com.au/forums/topic/115527-brake-upgrade/#findComment-2130240
so you can run GTR rotors with the GTST calipers can you?
Bolt straight on no worries?
Im looking at upgrading my brakes and was going to get the DBA 4000 and get some Bendix Metal pads and a cylinder stopper.
If so and its easy i might look into getting GTR DBA4000 rotors for it and motul fluid etc.
Also what is the advantage of having braided brake lines apart from the obvious being strong?
https://www.sau.com.au/forums/topic/115527-brake-upgrade/#findComment-2130334
The idea of the braided lines is to eliminate line expansion. When the old rubber lines expand you get a poor pedal response...the s/s braided lines which are teflon lined can handle the pressure and dont expand...increases your pedal feel and response. Its a definete for track work if you do it often.
Edited by r33_racer
https://www.sau.com.au/forums/topic/115527-brake-upgrade/#findComment-2131451
Where are you getting the Standard Size DBA4000 Slotted rotars from??? ....And what would I expect to pay for all four?
....I'd like to get some for my car :)
EDIT: Just realised ur in Brissie(im in melb)... Would I be able to get them from say a REPCO or something like that?
Edited by R33_STEALTH
https://www.sau.com.au/forums/topic/115527-brake-upgrade/#findComment-2131474
no, to run a GTR rotor you'll need an adapter bracket to use a GTSt caliper
in fact i think GTR rotors are 32mm vs 30mm thick for GTSt so might not be able to use a GTR rotor with GTSt caliper at all...?
Ask Roy :ermm:
I think it is possible, there are kits being developed for it at the moment
see here: http://www.nissansilvia.com/forums/index.p...0entry2172070
https://www.sau.com.au/forums/topic/115527-brake-upgrade/#findComment-2131782
Yeh they are good value, but I tend to think the upgrade best suits R32 GTST. The 296mm to 324mm upgrade only represents a 28mm increase in diameter, which is 14mm in radius, so the bracket to offset the calliper is difficult to do properly as you end up with such a small bit of steel/alloy with 4 big 10-11mm holes in it 
I think the NS person is also the same person doing these kits in the Group Buy section of SAU. IT will be interesting to see if ppl start running them and get the same results as I have…but Im just paranoid that the bracket isn’t strong enough. On the other had the 280 to 324mm upgrade is 22mm radius change and much more meat in the bracket…so, who knows
https://www.sau.com.au/forums/topic/115527-brake-upgrade/#findComment-2131947
Hi everyone
I got some rims that were the wrong offset (i live in Broome WA, no good rim wheel shops, and prices are ridiculous anyway) and grinded a bit off the calipers to make them fit, but ive got some new calipers on the way, and was thinking of doing the GTR 324mm x 30mm DBA4000 slotted rotor upgrade.
Roy - where did you get the brackets from for your conversion? As this is the only part i will now need so i can get the clearance i require.
cheers
Evil
BTW sorry for the post hijack :)
Edited by EvilINGT
https://www.sau.com.au/forums/topic/115527-brake-upgrade/#findComment-2132948
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
