Jason - Caliper kits - $20 per corner - Rebuild for free :)
DBA4909SL + SR's - $--- Pair (uh oh...super duper cheap price cannot be displayed)
Go the Hawke pads - cannot beat 'em.
That is all you will need. If your brake fluid is getting over 600 degrees then there is something wrong....you don't need braided lines. Standard lines hold well over 5000 psi cold. The brake fluid you are using will be sufficient to prevent brake fade in your application.
Edited by 3lit3 32
  • Replies 43
Hi everyone
I got some rims that were the wrong offset (i live in Broome WA, no good rim wheel shops, and prices are ridiculous anyway) and grinded a bit off the calipers to make them fit, but ive got some new calipers on the way, and was thinking of doing the GTR 324mm x 30mm DBA4000 slotted rotor upgrade.
Roy - where did you get the brackets from for your conversion? As this is the only part i will now need so i can get the clearance i require.
cheers
Evil
Hey, if the wheels in your pic are the ones you have then i run the same in 18". Race brakes in Sydney did my bracket, but they no longer do it. The only place i know of still doing the kit is Unique Autosports in Sydney.
Im going to get a few made for friends in a few weeks, so may get a few extras done
Jason - Caliper kits - $20 per corner - Rebuild for free :wave:
If you can get the rebuild kits for that price...well im happy tp ay a little bit exta as i need to rebuild mine and a friends and the ebst i can get is $100 for the front and still to get a price for the rear...hook a brother up:)
Jason - Caliper kits - $20 per corner - Rebuild for free ;)
The only place I found that had caliper kits was Race Brakes, and they were $20 per half caliper, so $80 for the front. If you know where to get them for half that then let us all know! I agree that rebuilding brakes is good too. For some weird reason I always trust the job when I do it.
You don't need bigger brakes to pull up quicker. If you can lock the wheels with your present brakes then they are big enough, unless they've overheated. Your tyres are more important than the brakes for hauling up quick. My GTR has shit tyres and the stopping distance is ridiculous even though it has Brembos. The biggest advantages that bigger brakes have is being able to dissipate heat better (less fade) and being easier to control the locking point of (larger diameter=more leverage).
Personally, I think the standard 4 pot GTS-t brakes are great. About 6 months ago I installed new DBA4000 rotors and RB74 pads (front only) with Falken FK451 tyres all round and it was one of the quickest stopping cars I've ever been in. The GTR has shithouse Wasabi compliance tyres or something stupid, and even though I've never experienced brake fade, it's much easier to lock up the wheels. I can't wait for them to wear out so I can fork out another $1200+ for good tyres that I can't afford :D
As for brake fluid, Caltex GP600 is one of the best value ones you can get for street and mild track use. It's only Dot 4, but it has higher temperature tolerance than some dot 5's and doesn't have squishy silicone in it. Minimum boiling point is 300 degrees C, minimum wet boiling point is 195 degrees.
Optimising the std gear, and making sure it is working right will give good results. I run DBA 4000 (albeit larger diam) and im a fan of how long lastign they have been...but i would tend to look around and find some std sized rotors that used curved vanes rather then Kangaroo Paw.
None of the high end rotors use the Kangaroo Paw rotor type, they all used curved vane, so with the Z32 takign the same rotor, surely there is a manufacturer somewhere that is makign curved vanbe rotors for R32 GTST/S15/Z32 etc etc????
If the choise comes down to Kangaroo Paw and straight vane i would definitely take the Kangaroo Paw.
well, i ended up ordering a pair of DBA4909 (DBA4000 Slotted) rotors, and some Ferodo DS2500 pads today...
does anyone know if DBA4000 slotted rotors are cast with the slots, or if the slots are machined into the disc after they've been made?
see this thread for more info: http://www.skylinesaustralia.com/forums/in...howtopic=116278
Where are you getting the Standard Size DBA4000 Slotted rotars from??? ....And what would I expect to pay for all four?
....I'd like to get some for my car :angry:
EDIT: Just realised ur in Brissie(im in melb)... Would I be able to get them from say a REPCO or something like that?
Try RaceBrakes...Last I priced 4909's for my GTST (a while ago) RRP was about $250 per rotor, but they can be had cheaper than that. SAU VIC Members get a discount too I think :D
While I am no fan of DBA's design philosophy which has caused significant problems on Roy's front end, and which they "fixed" with an idiotic reverse slot at the circumference they are popular and sometimes priced competetively so buy what is best priced. I prefer RDA myself and thay have the new slotted and dimpled design.
A stopper and good pads with slotted rotors is a great improvement but pales in comparison to braided lines which resist expansion under pressure when braking and not temperature pressure as wrongly stated previously. When incorporated with trail braking it lopped 3 seconds of my previous time at PI. The pedal travel is too great without braided lines so you contact the accelerator too easy. My GTSt brakes better than my GTR33.
Another point. GTR front calipers on a GTSt without master cylinder mods can cause the rears to pinch resulting in a taily car under brakes with too much pedal travel, even with ABS and I really didn't like the setup at all on cars I've driven.
Geoff, when you say the braided lines made a huge difference are you comparing to 10 year old rubber lines?
We put brand new rubber lines in the race car (braided not allowed at targa) and it also made a huge difference. My guess is there is minimal difference between new rubber lines and braided lines
R32 GTR calipers have the same internal volume as R32 GTST, R33 GTST, R34GTT so shouldnt cause a problem with master cylinder sizing.
Also the slots on the new DBA are different top what i got...as mine were some of the first 324mm DBAs to come out so you wont find many slotted ike mine these days
Still a 4% (from memory) increase in radius with rubber over braided which results in quite a large pedal travel when the total volume is tallied. The GTR and auto GTSt feels like pressing a sponge in comparison.
Now a clever business would develop braided teflon lines with an OEM look rubber sheathing....... But not everyone will waste a massive sum of money entering Targa Tassie.
From the Maltech site http://www.maltech.com.au/brakehoses.html
Why would you not change when circumstances allow?
Facts about Rubber Brake Hoses :
1. The average good working life of a brake hose is six years.
2. Brake hoses deteriorate from the inside as well as the outside.
3. Moisture is absorbed into brake fluid systems through rubber brake hoses.
4. Contaminants in brake fluid act abrasively on the inner wall of brake hoses.
5. The brake hose reinforcing fabric deteriorates through expansion and moisture.
6. High operating temperatures contribute to the deterioration of rubber brake hoses.
7. The brake hose inner diameter swells with age therefore restricting flow.
8. Generally all rubber brake hoses on a vehicle deteriorate at the same rate.
9. So all hoses should be replaced if one is found to be faulty!
Also Roy is correct. Busted arse old 32 GTR's have an almost identical caliper to 33 GTSt on the front which suits a wider rotor. I was of course discriminating and thinking of Brembos which are a step backward if only half done, but rarely do full sets come available. A full change up will cost about the same as a decent AP kit so why bother.
I've still witnessed similar accelerated wear on the outer area of the discs on track cars for DBA's with the silly reverse slot. I have DBA's on the GTR but will get rid of them when I recover financially from my seat buying flurry.
Coming together nicely there Azzurra
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
