currently 97 s2 with coilovers, front adjustable, back is too frigging hard to get to and therefore not adjustable ^&^, quick shift kit, active lsd, 2.5" cat back, hks injectors, size yet to be fully tested as I hadnt installed them.
my exhuast manifold is ok, the studs are all there, same with head studs so... for 5k
full 3" slowly getting to 3.5" exhuast with a tip that looks good but doesnt necesarily drone like crazy if possible
FMIC as im running around with shit smic
$600 GCG full steel rebuild of turb with bb cartridge
replacement ecu that IS compatible with my active lsd, vvt and will work with my existing sensors and give me a readout on my laptop, but finding something that will work with my active lsd is the shite
a bonnet fitted snorkel to my stock airbox like a reverse scoop and some decent 18" nismo white rims
hmmm soooo
$800 exhuast
$600 just jap imitation hybrid kit, the one with decently shaped end tanks
$600 turb upg
ecu > 1-1.5k
snorkel > probably replacement carbon fibre bonnet with reverse scoop i can duct to my stock airbox... 1-1.5k
nismo 18" white rims.....1-1.5k
thats 6.5k
sooo less the rims eh :teehee:
then the cost of getting it all in and tuned.... :O
tooo bad
bare essentials. first 4
decent power.... hmmmmm
funfun
  • Replies 63
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
