ATP turbo is releasing T3 flanged split pulse or divided non gated turbine housings for the GT30R and GT3540R (GT3582R) range of turbos . No details yet on which AR ratios they intend to do but may be useful for some . They are also selling the .85AR T4 flanged divided Garrett housing for GT40R based turbos .
Cheers Adrian .
whats involved in getting the rb25 to run split pulse? is it as simple as manifold change? or is more comlpex such as changing firing sequence of each cylinder + suitable manifold?
very good info, thanks a
OEM manifolds for the RB sixes are all split pulse (to an extent) already. the flange will be the same, they will bolt on.
personally i would never build a manifold with an open collector, even if i was using an open collector turbo. split pulse all the way. the less pressure spiking you get transmitted to the other three cylinders the better IMHO.
ok right. so its just a case the standard turbocharger doesnt run split pulse.
so it should be as simple as bolting on a split pulse turbocharger and thats all u need to do. cool cool. i was under impression you would have to change the manifold and firing sequence to suit.
split pulse works in the sense say
cylinders 1,3,4 fire
into pulse zone 1
and cylinders 2,4,6 fire
into pulse zone 2
so the engine fires in order 1,2,3,4,5,6
and this results in gas flowing through each pulse zone in well "pulses" which keeps the exhaust wheel spinning at the best possible rate
or is the goal of split pulse to avoid collision (so to speak) in the manifold
ie: no two firing cylinders at the same meet up in the same pulse zone?
the firing sequence of the RB sixes is 1 5 3 6 2 4 IIRC - you will notice that each of the three cylinders linked by a common collector are separated by the firing of a cylinder NOT linked to it.
when your back pressure spikes due to an exhaust pulse, you don't want that pressure spike being "seen" by another cylinder just as the exhaust valve is open there too, it will hinder gas exit and increase the work of pumping. so you separate them as much as you can.
ideally then, six independent pulse housings would be ideal for your turbo, but it's just not practical. even better would be six individual tiny turbos, but that would simply not work.
    • Cleaner signal so timing is more accurate at all rpm also found it to start more on first rotation but could also be I've nailed prime and crank fuel. For under $400 and 30mins of your time, its a good solution especially once the optical sensor does start to play up you won't notice it until in higher rpm and it heat soaks.
    • On a 400hp RB, what benefits other than "it's not 30+ years old" are you seeing from the NZ Wiring Kit trigger setup? If it were me going to change triggering, my belief would be to go for a crank trigger to remove the issues caused by what people claim is belt stretch etc, but that's from my understanding a much larger issue for super high power, rather than those in the 400hp and below club.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
