i own a r33 s1 sedan and ive all ready got a wheel alignment i let go of wheel and it is straight as can be
i have just purchessed this car and it is mint condition had to changea few things got a new turbo filter and new brackets for the turbo filter alot stronger ones got it serviced and racv tested all green good to go but the shakes where happing b4 i took it in to get it fixed and still same problem it has the shakes any one know how to fix or have same problem or what needs to be fixed it is very disturbing to me if so plz they missed it in racv test
Edited by R33sedanturbo
https://www.sau.com.au/forums/topic/115545-stearing-wheel-shakes/
Shaking isn't due to a bad wheel-alignment, it'd be due to a bad wheel BALANCE.
Take your car down to a tyre-place, and get them to rebalance your wheels. They place a counterweight to stop that shaking at speed.
I'm assuming you only really feel this shake above 70ish? If so, it's not hard for them to miss it, if they don't drive it far or fast.
I am also owner of two 33 sedans, sounds like one of your wheel weights may have come off, causing one of your wheels out of balance. Or, it could be caused by your brake discs being warped (will shake then if you place foot on brake). If it is happening under brakes a very slight shake is normal (since disc brakes are machined very slightly out of round to throw pads out). If you could explain when the shake happens or perhaps try to explain it a bit better I may be able to get a more accurate idea!
Cheers mate
it doset shake at 70ish it starts to shake at 105 then when u get higher to 110 then it gets worse
at 70ish i dont know if it is a minor shake or not hard to tell at 70 ish but 105 it is really bad it dosent shake when u brake breaks are perfect couldent have em better
Go to a good typre shop and get them to check your wheel weights. get them balanced just like what RANDY said. And one other thing, you need to take english and grammar lessons.
i would also get a wheel balance. BUT if that fails which im thinking it might. you need new tyres. I had the exact same problem, the car would voilently shake on exactley 110km/h. i know exaclty how you feel its very unsettling to have the car shake like that.
just go get a wheel balance, if that doesnt fix it, first replace your front tyres and it should fix your problem, if not try replacing the back also and it should be all smooth. i know its an expensive fix but i racked my brains trying to find the problem and ended up getting 4 new tyres for rego and it was fixed.
Edited by joh21m
LOL!
There is also such a thing as a "high speed" wheel balance. Most places will just do a standard one, i'm not sure how fast the wheel spins in their balancer, but the high-speed balance should spin it up to 100+.
I didn't mention the braking wobble (which I have severely right now) because you said nothing about braking. If you brake and it goes away, it would suggest that you need a wheel balance or possibly check out your wheel bearings!.
Jack the front up (off the crossmember, never off the sump), then grab the top and bottom of the tyre, and try to pull the top towards you and push the bottom away. It's like checking a turbo for shaft-play, your wheel should have pretty much zero play. If it does, it will cause some wobble, and may even fail rego!
Thats what I did but, I had shakes at a higher speed than 110km/h & it ended up being dodgey sidewall on one of my tyres. If it still happens after getting a wheel balance & before resorting to replacing tyres, check for loose steering linkages/ bushes etc.. or get a suspension safety check.
Ok i got a wheel balance to day. It seems to have fixed the problem the guy said the old ones have been taken off so there where no balances on em at all. Now i have balanced tyers and i did 120/h really quick and there was no shaking but he also check my brakes and suspension they are all good but the front tyers have some low and high spots on em he said that can cause this problem as well but it seems all good but will get new tyers soon any way and some rims
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
