just thought i show off a project of a rb26dett install in to a s13 silvia that i am doing for somone at the moment
the engine is from a r33 gtr (v-spec i think)
i have removed the gtr sump and modified a r32 gtst sump and oil pick up to suit the gtr engine so it will fit into the s13
i am using a rb25det gearbox with a jim berry clutch rated at 600hp (has a 3500 pound pressure plate)
we have painted the cam cover coil cover and plemium in a kandy red which is what the car is being painted in the cam covers are polished
the engine will be standard for now (no big turbo(s) and i will wire up the factory ecu
later on we will be chasing around 400rwkw
i will be doin all of the work myself (as i have done lots of these rb conversions) (ie custom alloy pipe work for cooler , modified tail shaft to suit rb25 yoke ,custom gearbox mount etc
i know its not a skyline but its got a gtr engine in it :worship:
i will post up more pics as i progress along with this project
Edited by boot_it
https://www.sau.com.au/forums/topic/115570-rb26dett-in-to-a-s13-silvia/
Guest
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
