Ok guys this was for sale ages ago and took it of to mod some more. Still not really keen but have decided its either i keep moddin this til its not street registerable or buy somethin already set up so here goes
1989 A31Nissan Cefiro
Features
Power Windows
Climate control air conditioning
Electric Folding mirrors (east bear)
Power Steering
Exterior/ Interior
Exterior Colour: Purple with a pearl
Interior Colour: Grey with black carpet
Full monkey magic body kit
Boost Gauge
Apexi Power Fc Hand controller
Sony Xplod head unit New speakers under standard grills
Bonnet has also been lifter to be more efficient in coolin
Suspension/ Wheels
Tein fully Adjustable race spec suspension with Adjustable camber kit front end
15” front rims 3 piece light weight racing rims
16” Oz Racing Rear rims with 80%
also a set of drift rims with 70% rubber
Gearbox/ Clutch
R32 Skyline Gearbox
Excedy 5 puck clutch to be fitted Thursday
Modified master cylinder
2 way LSD unsure of make
Engine
RB20 from a R32 Skyline
HKS 2510
3” custom dump pipe with divided waste gate
3” Exhaust with high flow cat into Cannon
Front mount intercooler custom plumbing
Pod Filter
Plumb back BOV with custom mounts
GTR radiator
Pneumatic boost control 10/15 psi.
Bosch 040 intank fuel pump 550hp rated
GTR injectors
Standard plugs
Apexi Power FC Is yet to be tuned with the HKS 2510 but hoping for 260rwhp on 15psi will be tuned this Friday by Charlies Motors Brisbane. Also comes with engineers certificate for exhaust and front mount intercooler. Also has 12months rego
Can also supply 8point cage an Bride bucket seat.
Contact Jamie on 0438874234
$17500
Edited by nytrda
https://www.sau.com.au/forums/topic/115579-purple-cefiro/
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
