I have been toying with this idea for quite some time.
Is there a big enough benifit of changing to Thermo fans?
Does anybody have the fans hooked up so that in normal driving they don't come on at all until about 85 degrees?
Is anybodies cooling system efficient enough to control temperatures without a constantly running fan?
My old VN Commodore V6 never had a clutch fan, and it did perfectly fine......
BASS OUT
My 14's are hooked up to switch on at 85 degrees. The only time the temperature actually gets that high is when sitting still or on a hot start (heat soak), when driving for any length of time temps typically drop to anywhere from 80-83 degrees.
I also run a 40mm china alloy radiator.
yer i was planning on twin thermos for my 33 but yer ive put it back up for sale again anyway so there really isnt any point pouring more money into it.
Thanks for all the advice and oppions guys. Will keep it in mind for a future car.
Oh and by the way about the whole thing about some people not liking thermos and would rather the clutch can, Im sure it would be a greater HP increase from using thermos + better cooling. As was said about the power useage i think it would be less strain on the motor using a little more power then a big heavy viscous fan?
  • 5 months later...
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
