To run the RCAs from the front to the back all the skirting on the inside of the car unclips and lifts up. Now to get the RCAs from the back seat to the boot is a bit tricky, what you need is a unravled wire coat hanger or some wire. On the side of the seat pull it away from the edge of the door and stick the coat hanger/ wire through so it reaches the boot (it took me about an hour to achieve this so it may take a while) now make a loop in the wire and make sure that it is fairly tight around the RCAs and pull it through from the boot. It is not a quick task but is extremely dificult.
Now clip all the skirting back together and it should look like nothing is running under it.
https://www.sau.com.au/forums/topic/115605-rcas/#findComment-2128030
I loosened the seat-bolts.. bum and back. Then lifted them up half a meter and just poked the RCA's through one of the little holes that go into the boot. There is already a wiring harness that runs up that way, so turn on and test the unit before you put the carpet, seats and stuff back in. Interference in the RCA's is a common problem in R33's it seems.
https://www.sau.com.au/forums/topic/115605-rcas/#findComment-2130749
Cheers dudes, my mate sugested going under the centere console slicing a hole in the carpet on the tunnel feed in under the seat etc etc, but the trim on the sil seems the way to go, about the rca interferance wat would cause that..........i got earths on my rcas iwasnt going to earth them( my last intall i didnt, worked fine) but i might now.
https://www.sau.com.au/forums/topic/115605-rcas/#findComment-2133525
Pulling the seats out and back takes less than 1/2 hour and allows you to tape/zip tie the Rca's. I ran mine down the transmission tunnel to the back seat, A fair bit harder, along te side would definatley be better.
https://www.sau.com.au/forums/topic/115605-rcas/#findComment-2133650
There is a harness that runs up the side already, try to stick to that.
I removed the rail that holds the seatbelt on, as it was neater to go under that. Easy.
The door-sill pops off with a gentle tug.
Remove the kickpanel where the ECU is, one nut on the footwell, then there's just two clips holding the side in, tug it off.
There is a round section next to the passenger seat, under that moulded piece of carpet there is an upside down U shape, where the wires can run over very nicely. You can work out the rest, but those minor details may help.
https://www.sau.com.au/forums/topic/115605-rcas/#findComment-2135158
    • Evening fam, Pretty much what the title asks, I have looked all over and can’t find a proper answer expect one post from almost a decade ago which is vague. ive seen photos and they look pretty much identical, would an r33 GTR N1 reo work on an r32? reason I ask is they are cheaper to buy… $700 compared to 1k+ for an r32 n1 reo
    • Couldn't help myself, had to start putting it together.... It really is a solid bit of kit.  Probably stronger than i would have made it myself to be fair! 🤣🤣 Sweating like a pig after that.  Bloody hot and muggy day today, time for a swim now!
    • Yeah was thinking that. I've had the car go lower idle possibly around 650rpm every once in a long time after pouring fuel and would sound quite rough like a misfire, almost like it's shit fuel or something but who knows.
    • @Wazmond you are correct, my bad, was not my intent    https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.    I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.    I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.    https://gtrfestival.com.au
    • Just buy a bunch of covers off aliexpress, they're like $5 each. Rattle-can them and stick them on as needed/fly off.
