Saw one of these on the way to work in peak hour traffic, so couldnt really have a run with it. Looks like a normal xr6 but has turbo underneath the xr6 logo on the back. I think from memory they are supposed to have somewhere between 250-300kw. So be an interesting drag, I dunno how tweakable they are either. Might even see one at the drag wars :P Stock form I think they are a mid 13 second car... I think it was HPI who did a bit of a write-up about 3-4 months ago when it was still developmental.
https://www.sau.com.au/forums/topic/11561-falcon-xr6-turbo/
  Quote
Originally posted by Boostzor
Id hardly call the volvo a "family" car :P
It is so!
Its got two baby seats in it and a pram in the back at all times.
Its a wagon so its even more of a family car than the XR6.
Only part of the interior that doesn't look family is the B&M megashifter.:)
https://www.sau.com.au/forums/topic/11561-falcon-xr6-turbo/#findComment-197770
Yup 240 Kilowatts and 1690Kgs...
Oh has anyone mentioned that it actually failed 2 of the wheels magazine tests before it somehow won car of the year *gasp* yep thats right! Pls explain to me how it can win car of the year when it failed 2 tests.... especially when one of the failures was over heating! *please note this is not a rumour i have read this with my own eyes. www.smh.com.au if my memory serves me correct!*
Also Ford has come under fire lately of it being 2 heavy for it's power, therefore they are undertaking some major projects to reduce weight! and a lot of it by the sounds of it.... seems wheels car of they year i s a little bit over rated.
I do agree it is fantastic that ford is doing this however, more testing should have gone into it and perhaps a bit more thinking whats the house of having 240 kilowats when your car weighs as much as a frickin tank:uh-huh:
https://www.sau.com.au/forums/topic/11561-falcon-xr6-turbo/#findComment-197821
One thing i do remember reading somewhere is that the stock computer remembers how much boost is being run, so if you up the boost, the computer will note this and it will void your warranty... Now i can't remember if i read this in a forum or in mag, but i'm pretty sure it was a mag...
https://www.sau.com.au/forums/topic/11561-falcon-xr6-turbo/#findComment-197975
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
