hey guys,
i have found an air con set that i can buy however the condensor is from a series 1 r33 and i have a series 2.
will i be able to put this condensor into my car without any troubles?
cheers
hey mate i have a series one and series two in the driveway and they are identical as far as the condensor goes , i would be conserned about all the seals and what not in the compressor if it has sat so long with out any gas in it you(the gas has the oil in it for lube) will need all the lines fan switches etc
hey man,
once i get the condensor and dryer im going to take it to a air con shop and get them to install it and fix anything that needs fixing, im sure they will have all the seals needed to do the job.
her is a pic of the air con pipes and charcoal cannister as they are now.
im pretty sure i have everything i need bar the condernsor and dryer.
cheers
hey man,
cheers
failing that, does anyone have full pics of their air con units so i know what im missing?
cheers
