I dont really think it is.
When i smashed my car my fiberglass front bar was absolutely shattered in peices on the ground, the cop never said anything to me. If it was a big issue i would say he would have fine med on the spot because i can assure you he did want to fine me on the spot but he had nothing to get me for.
he would have had to be a real heartless bastard if he fined u for anything
lmfao trust me he was an asshole
He turned around to me and said that if it had of been dry he was gonna fine me on the spot he didnt even ask me what happened or if i was ok he just walked straight up to me and said that.
when i smashed my 33 a few weeks back..i had no dramas formt he cops...they were quite helpfull...and were only concerned about my safety....lol wet+r33+boost=trouble.
good new is new front bar and stuff...gonna look sweet.
The VS one is ok but i never been a fan of VS...the rear looks good tho...but on the R33 it looks nicer than than when I had one on my fto...in the end I went custom now it rocks....urs is gonna be sweet.
eh? illegal? now thats the first time i heard its illegal =S it wont really bother the cops because as abusd mention they will sus out other things, and the only illegal part i know to be fabricated with fiber glass is the bonnet as mavric had mentioned. sooo... JUST DO IT! get the whole kit ^^
well ive got a d-speed front lip, veilside skirts and geniune east bear rear pods..and its booked in to get painted up and fitted this week, so hopefully it will be ready this sat or early next week.
im getting the kit sanded, hi filled, paint match, supplied and fitted for $550, which has taken me around 20-30 phone calls to get but its the best price i got and the work shop is pretty good from what ive heard, ill post the pics of the kit in fibreglass form prob tomorrow and ill post the pics next week with the kit on the car, so u guys can get ideas if u planm to use any of the same panels :P
well the skirts photos are on pg1. Here is the front lip which i purchased from powerplay imports , and i must say the fit was perfect.. It may not look it in the pics, as the lip didnt fit first shot as it hit my aftermarket cooler pipes, and inturn the sides stuck out, so i am getting it cut and sprayed today.
also here is a pic of the east bear rear pods on the car, as these are geniune they fit like a glove, and match up on the factory panels seemlessly. in this pic still had those black plastic things on the back of the guard so it didnt fit, but once i removed it, it sat like a champ
The hi fill, sanding,painting etc is getting done today and hopefully the fitting will happen later this wk or early next week. ill post pics as its done.
thanks again to Jo and powerplay imports for all there help in getting my project into its finishing stages, they truely know how to keep their customers satisfied
Edited by mr_crust
  • 1 month later...
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
