Hi everyone,
I was talking to a guy that drives a tuff 32GTR at the local Hill climb. From what I was told the car has N1 turbos, Autronic, most likley a lot of money spent on the motor, it has a two stage rev limiter setup, its making 350KW, I assume its at all four and it runs a 10.3 or 10.4 at the drags, the car is pretty much full weight.
I was talking to my mates about it and they all seem to think its quite possible, I wouldnt have thought N1 turbos could produce 350rwkw, and I would think you would need a lot more than 350rwkw to run a mid-low 10?
Has anyone got any oppinions on this as it could solve our argument!
Cheers Eddie.
https://www.sau.com.au/forums/topic/115641-does-this-sound-right/
giant (qld) has run a 10.4x if i recall with his R32 GTR/N1 turbos
Around 380rwkw... thats on fuel though and a dog box
So it might be possible. Who's to say he wasnt running a race fuel tune for the drags etc?
There are many variables that you havent provided for an accurate yes or no
Yeah R31 Nismoid, I didnt include all those factors because I didn't know them. Maybe the car your thinking of is the same one I am talking about because it was trailered to the event and I think its from around Brisbane area. It could well have been on race fuel, no doubt it had at least semi/slicks, I just had the feeling that N1s could only flow about 300rwkw and I would have thought that would be a long way off a 10sec pass.
They are. Trust me.
Russel is on there. Username: giant
You'll see him in the motorsport section mainly :D
I've met the bloke personally aswell at a recent AutoSalon Circuit battle in NSW that Russel and co-driver Mark took outright honours.
I would no doubt that car for a second. Its a well built car, so well setup and its got all the times to prove it.
Definately running N1's.
380rwkw on fuel is not out of reach by any means.
Yep thats the car. He is a nice bloke, I only doubted it because you see people putting big turbos on GTRs and they dont seem to run such an impressive time. I am pretty sure he said it only makes about 350 but that might have been on the setup for the hill climbs or something.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
