The greater Sydney area really needs a racetrack with a few loooong straights and big, open, sweeping corners so the mega HP cars can really stick it to the 'light atmo car' boys....Fatz :pwned::(
:D
Get cracking on it then :)
  • Replies 234
Posted Images
Yogi,
Im not sure, he id run one about 3 months ago, but he lost $5-8K so I dont know how many more he will be running. I dont think he has booked any more days at this stage. I guess if he does not get enough support for these events moving forward he will have to stop running them AKA Moto concepts.
Just wondering guys, down the back straight will I be hitting 180+?
I've got my speed limiter still on but I don't want it affecting my times.
My car is a 190rwkw gtst. :mrt:
definately not! there is no back straight at OP. well there is a short one between turns 3 and 4 but you will be lucky to hit 120 there.
depends how good your entry is onto the pit straight as to whether or not you hit 180. plus in my experience mostly the limiters wont cut in until an indicated 190-195. i wouldnt worry about it mate. it should be the least concern if this is your first track day.
He will worry about if its his first track day... You will be hitting about 180 right when you need to hit the first kink/turn and if your not expecting to hit the rev limiter you can shit your pants and at that speed you want to aleast be aware of it.
When your times look shit, its also an excellent excuse as to why you times are poor... Just go with the story that you hit the speed limiter half way down the straight and that you should be 3-4 seconds quicker :P
yeah true, but i dont know that an auto 33 will even hit 180, and being first time out he will be hard on the brakes bro! on the brakes! at the kink :P
good point though, just be aware of it wink, but dont let it stop you.
    • Unfortunately,  it feels like it's been on the decline for nearly a decade. Especially as wallet racing became popular with them(biggest wallet can pay off a car that wins). It seems like a different mindset kf ownership these days. But, hopefully people like yourself keep some of the skyline scene alive.
    • A bit of data is always good, beats the Facebook experts with their opinions Although the kWs aren't anywhere near what you are after, it should give you a good indication. I have Bosch 1480cc injectors, often called 1650cc (only when run at 4bar). I run mine at 3bar base so I don't thrash the fuel system. Up top, making 437kW with boost dropping, injector duty is at 69% on E80 (might have had some residual 98RON in there)
    • I have some downtime due to winter, and just wrapped up converting the car over to flex fuel. We don't get E85 at the pump over here in Canada, but I will be running Ignite E90 Race gas. I'll be mixing it with 99-100 RON pump gas and shoot for 50% ethanol content, up to possibly 85% content if there's any noticeable gains. Here's the question. Most I'll ever want to hit is ~600rwkW. I've currently running 1200cc injectors and want to keep them under 90% duty cycle. As per some online injector calculators, I should be good with 1200's well past 600rwkw on E85. As per other calculators, I'll need 1600-2000cc's. The variety is rather amusing.  With you Australians having E85 at the pump, what realistic duty cycles are you seeing in those kW ranges on E50 & E85 on your injectors? Thanks,
    • No issues here with my PRP gears in an OEM pump housing. I did confirm all housing clearances were to spec prior though. Cheers.
    • Thread is a bit old but figured id give my input anyway just incase. Have had lots of water problems in my R32 and was getting sick of wet tools in the boot and water filling up half my taillights. I ended up finding that whenever my car had been repainted they didn't reseal the taillights to the body of the car so water was just flowing straight into the boot, this is amplified by all the water around the bootlid being directed down to the taillights so would get pretty wet whenever I washed the car or it rained. You could probably use silicone to seal them to the body but I think from factory they use a roll of automotive grade butyl rubber. Hopefully this helps you if that ends up being how the water is getting in on your car!
