The greater Sydney area really needs a racetrack with a few loooong straights and big, open, sweeping corners so the mega HP cars can really stick it to the 'light atmo car' boys....Fatz :pwned::(
:D
Get cracking on it then :)
  • Replies 234
Posted Images
Yogi,
Im not sure, he id run one about 3 months ago, but he lost $5-8K so I dont know how many more he will be running. I dont think he has booked any more days at this stage. I guess if he does not get enough support for these events moving forward he will have to stop running them AKA Moto concepts.
Just wondering guys, down the back straight will I be hitting 180+?
I've got my speed limiter still on but I don't want it affecting my times.
My car is a 190rwkw gtst. :mrt:
definately not! there is no back straight at OP. well there is a short one between turns 3 and 4 but you will be lucky to hit 120 there.
depends how good your entry is onto the pit straight as to whether or not you hit 180. plus in my experience mostly the limiters wont cut in until an indicated 190-195. i wouldnt worry about it mate. it should be the least concern if this is your first track day.
He will worry about if its his first track day... You will be hitting about 180 right when you need to hit the first kink/turn and if your not expecting to hit the rev limiter you can shit your pants and at that speed you want to aleast be aware of it.
When your times look shit, its also an excellent excuse as to why you times are poor... Just go with the story that you hit the speed limiter half way down the straight and that you should be 3-4 seconds quicker :P
yeah true, but i dont know that an auto 33 will even hit 180, and being first time out he will be hard on the brakes bro! on the brakes! at the kink :P
good point though, just be aware of it wink, but dont let it stop you.
    • Hi Lads Anyone have or know where i can find the wiring diagram for the dash cluster of a 2003 V35 Skyline? The G35 one is not the same as the V35 Thank you!
    • Ok will do, I think I originally had 1 bolt off for the sway bar on when I took off the strut but will give this a ago. Thanks Duncan! My sway bar has play also when I move it around, hoping that's the source of my squeaking because I can't find anything wrong elsewhere
    • odd. I thought all the top race teams used them.
    • undo the sway bar link, put it on last. put a jack under the outer ball joint on the lower control arm to raise the hub and off you go
    • I don't know how this is even possible. I removed the strut to do some work (it came out fine, and keeping in mind that I didn't put things back in the same order, but did this on purpose because I was supposed to remove the strut originally instead I tried to remove other shit first which made things a head ache) but now the problem is that it won't go back in. The alignment between where the bolt hole for the strut is and the j arm where the strut slides onto is way off, about a 10cm difference or more. In order to make it fit I'd somehow need to push it up. I tried to compress it with a spring compressor and install it but the compressor was getting in the way and there was no working room. On the photo you can see the difference between the shock and the thread that it's supposed to go on. The only things I removed in total were - the top bolts for the j arm but I didn't remove the actual j arm - the 3 bolts that hold the plate for the brake lines - the sway bar link (this bolted on back fine) - the strut/shock absorber
